Question about HP Pavilion a1102n PC Desktop
Windows has recovred from unexpected shutdown
  • Rinoo Kumari Oct 24, 2010
    Which Windows? XP or Vista or 7?
    Scholar:
  • 118 Answers
Hi, I would like to help out.
This might hapen if you dint shut down the system properly or somebody might have just turned off the power else would have pressed the power button.
Please don worry, just disconnect the plug from the power socket and press the start button in the CPU for 10 - 15 seconds. then plug in and try to turn on the system. It'l work fine.
If the problem still exists please let me know if you need more help. Thank you:) Good luck.
Please vote if you think this solution will help other.
Posted on Oct 24, 2010
    New Friend:
  • 34 Answers
Tell me more about this problem
SOURCE:
Windows has recovred from an unexpected shut down
This message was displayed only because the last time system wasnt shut down properly don't worry and continue to work
Mar 03, 2013 | Dell OptiPlex 780 MT Desktop Computer...
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
Windows has recovered from an unexpected shoutdown
That is a common message that most of us see at one time or another, the cause could be a bad download, device driver issue, or a glitch in windows, or windows did not shutdown properly.
Mar 21, 2012 | ASUS Computers & Internet
Windows has recoverd from an unexpected shutdown
This can be caused by an improper shutdown, a download, or just a glitch in the windows operational system, In most cases it recovers without a hitch.
Jul 02, 2011 | Microsoft Computers & Internet
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Computer has lots of unexpected shutdowns.
it might be caused by virus, windows gone corrupt, needs new installtion with an updated virus cleaner.
Sep 26, 2009 | Microsoft Windows XP Professional for PC
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
Hello, some times my computer just shotting down unexpectedly. Few min ago it went to blue screen all of a sadden with fuzzy righting and then in about 7 sec it shoot down and started restarting on it's...
The blue screen comes becoz of unexpected shutdown...If it comes more than once then ur system files may be corrupted ...Try to reinstall Windows...
Nov 29, 2008 | HP Computers & Internet
Open Questions:
AVAST tEch SuppOrT pHone +++1{8OO}+8O31O69 NumBer u.s.a-24/7 Usa AVAST USA phone number is ranked #2 out of 2 because 7,728 AVAST USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVAST USA Tech support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AVAST USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVAST USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVAST USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVAST USA Calling AVAST USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVAST USA Tech support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVAST USA's Tech support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVAST USA's phone numbers against each other. Contacting AVAST USA in General While I8OO8O31O69 is AVAST USA's #2 most popular phone number, it's not the only way to get a hold of their tech support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVAST USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVAST USA.
Oct 17, 2019 | Best Computers & Internet
See all HP Pavilion a1102n PC Desktop Questions
HP Pavilion a1102n  PC Desktop Logo
43 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
