Question about Kenwood KDC-4590R
How do i stop my kenwood kdc-4590r ejecting disc when i start the car
SOURCE:
shagone
  • 34 Answers
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Posted on Jan 08, 2009
  • 80 Answers
SOURCE: Kenwood KDC-MP438U and Nissan Pathfinder Steering wheel controls
you need an aftermarket PAC!
it will work just fine!
Posted on Feb 26, 2009
SOURCE: Kenwood KDC-C717 - E-99 error
There is probably a jammed disc or disc holder. It cant eject the cartridge because the unit cant put the disc back into the cartridge to the left.
Took me a about 20 mins gentle persuasion after removing the plastic front (carefully depress the little plastic clips on the edges and (again, gently, lever the front off) and removing the metal case - half a dozen screws each side and remove the bottom. The top stays fixed to the workings. I could then get into the gap between the top case and workings but be careful not to pull the unit from the rubber antishock mountings etc. and remove the problem disc.
I removed the plastic fascia which surrounds the magazine hole too, not sure if it was necessary..!
Again - be careful not to be rough with it, you dont want to snap the plastic clips, etc and also check the horizontal/vertical adjusters are back on in the correct position if they come off.
Posted on May 16, 2009
  • 773 Answers
SOURCE: I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Posted on Dec 15, 2009
SOURCE: kenwood kdc-119**
lost the plug for my kenwood kdc-119 cd player. i made a plug but the wiring color is not right. can anyone tell me what they are from top left and go right, then bottom left and go right? thanks
Posted on Dec 08, 2010
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Kdc-4537ua sound i c number
not my expertise I am afraid
Aug 27, 2011 | Kenwood KDC-4590R
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
Open Questions:
Kenwood KDC-4590R Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
