Question about Arris SURFboard SB5120 Modem
What if the link light is flickering slow? - Arris SURFboard SB5120 Modem
    New Friend:
    Problem Solver:
  • 8 Answers
I wouldnt worry about the link light, it blinks when there is information being traveled through your ethernet to the computer from the device, its fine. sometimes its slow, and sometimes its fast, but unless your not able to connect to the internet i wouldnt worry, and f you cant connect than your haveing issues with something else not the link light....i hope this helps
Posted on Oct 30, 2010
SOURCE:
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
What are possibles problems cuasing the dashboard lights to dim?
Having exact same problem. Dashboard lights for fan speed & Temp. setting flickering & power windows slow when closing. Happened same time.
Aug 25, 2014 | 1997 Mitsubishi Montero Sport
Why would the oil light keep flickering from green to yellow. Why would it go from 3000 rpm down to 2000 rpm on its own?
sounds like the engine is going into limp home mode. it thinks you are low on oil. there is a float in the oil tank, when oil is low the float hits a switch. the low oil light comes on and engine slows to save it from running oil lean. see if that float is sticking low in the tank
Dec 15, 2017 | Boating
Oil light flickers at idle
Could be the idle is too slow.
Most guys like that "Potato" sound at a slow idle. However, to get that sound the idle is lower than factory recommendation. This actually causes the oil pump to not produce enough oil pressure (oil light, anyone?).
Try speeding up idle to around 1,000 RPMs.
The recommendation on my S&S motor is 950-1050 RPMs, just for example.
Jul 04, 2013 | 2003 Harley Davidson XL 1200 C Sportster...
Battery light flickers. new battery light still flickers. tested and alternator not charging battery. i do i determine if its the alternator or the fuse link?
Usually it is not a fuse link, but use a test light and check that you have current at the main terminal on the alternator. If you do the fuse links are fine, so next check your belt tension this is something that is overlooked often and is the cause of flickering alternator lights. Also check and make sure your cable ends are clean and tight. If all is fine that alternator or the voltage regulator in the alternator is going bad.
Mar 02, 2010 | 2003 Honda Civic
Clock and radio lights flicker and dash lights partially out
ITS THE BULBS IN THE DASH, BUT IT SOUNDS LIKE THE ALTENATOR IS GOING BAD IF ALL OTHER LIGHTS FLIKER,IF JUST THE RADIO LIGHTS ITS POSSIBLY JUST THE RADIO LIGHTS GOING OUT
Dec 04, 2009 | 1997 Ford Explorer AWD
86 lincoln town car oil light flickers
There is a sensor on the driver side on the oil pan. Either the sensor is bad, or has bad connection or you are a quart low.
Jul 03, 2009 | 1986 Lincoln Town Car
2002 chrysler concorde lx low idle
with a 2002 Concord 3.5 V-6, what should the rpm be at 60mph? 70 mph?
I'm not sure if the overdrive gear is lost in the tranny, but the transmission light is on.
Thanks
Apr 05, 2009 | 2002 Chrysler Concorde
Arris SURFboard SB5120 Modem Logo
159 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
