Question about Mitsubishi WS-65511 65" Rear Projection Television
Hello. I am very distraught, can you please help? I came home today to find that my tv has a grey, horizontal line running across the top of the screen. I tried the usuall trouble shooting technics, but was unable to come to any kind of conclusion other than "Im screwed". Is this problem one that you have heard of before?
    Problem Solver:
  • 6 Answers
I have made some posts on Fixya today, because my buddy and I fixed our rear projection tv in minutes and wanted to encourage others to do the same. Same thing happened to us and we went on line to find our it is the bulb. It wont just go at once but will radically degrade. Just go to dlp lamp replacement and they will get you a new one and walk you through it over the phone if need be.
Posted on Sep 27, 2008
Balancer repair
Normally horizontal line [a thin vertical line across the center of the screen] fault with CRT based TVs is the fault with its vertical scan output section circuit. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 11, 2016 | Televison & Video
FIXS LNES IN TOSHBIA SRS WOW THEATER WIDE TV !
sounds like vertical retrace lines. The horizontal line fault called so. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 23, 2016 | Toshiba 32A33 32" TV
Toshiba 36HF12 TV has a horizontal bright line across no picture
Failure of vertical scan output circuit. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 11, 2015 | Toshiba Televison & Video
Dell inspiron laptop grey dotted line across
You could try removing the display device in device manager then rebooting. At boot up windows will reinstall the drivers.
Check for new display drivers at Dell's support site.
Mar 13, 2014 | Dell Inspiron E1505 Notebook
Red Retrace Lines across tv? Can't find convergence box to fix it...
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
May 11, 2017 | Mitsubishi VS-70707 70" Rear Projection...
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Horizontal grey lines and tv cuts off by itself after 10 sec
Anyshop would take this under coinsignment as a bad Horizontal IC
"intergrated circuit"
But do not shoot the messenger, its going to need a shop, I would not recommend you opening this unit and risk a fatel shock or Death. Just the flyback transformer alone could kill you. Not to sound harsh but please understand, I do not want fixya to be on the late night news that it gave someone a solution that could have caused injury or death, if your not experienced take it to a shop. You cost if it is a IC witch it sounds like to me your looking $75-$100 parts and labor.
Thanks for your intrest in fixya.com please do rate and leave feedback.
Jul 13, 2010 | Philips Magnavox TP3285C 32" TV
GREY BANNED OUTPUT
It is symptom of dirty / clogged video head.
Please use good quality mini-dv video head cleaning tape to clean head. Problem will be resolved.
Mar 16, 2009 | Canon ZR850 Mini DV Digital Camcorder
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
