Question about Vizio High Definition Sound Bar
Installed a Vizio sound bar and subwoofer. Connected the tv to analog 1 and my DVD player to analog 2. Could only get sound from my tv no matter how many times Input button to change. Finally switched my DVD to analog 1 and got sound. what can I do to make it wrk right?
  • mccall_patri Oct 24, 2010
    I am thinking that the problem is a control issue. That is, that the unit is not switching from Analog 1 to analog 2 or the optical input. The unit does not give info on which input is operational. Maybe I should exchange for another? It's supposed to be simple, but has not been so far - except for plugging everything in.
  • Vizio Master
  • 11,800 Answers
Yes, the unit is extremely simple: a power source, an amplifier circuit with multiple outputs, a converter for the optical input and a controller - which only job is to start/stop it and select the inputs.
In your case the controlled is non responsive.
Just get a new one, and test it before taking it at home.
Posted on Oct 24, 2010
  • 4,924 Answers
Probably they are on a frequency compatible only on the first input ...so if you want to use them both ...either use a mixing device or an adapter to let you insert them both in the same plug ..anyway ..Im not sure why you go for analog stuff ..and didnt used the regular entries for Tv and dvd ...Probably it doesn't have such thing ..Most systems have though..IN this case...if this is the only entry that works ..you have to use some kinda mixing device to make more than one entry to be channeled in one in-let..
or ..use something like that for to get them both in the same entry ..
this is for a 3.5 jack plug http://www.shopmania.ro/magazin~online-accesorii-audio-video~produs-adaptor-jack-3-5-mm-tata-2-x-3-5-mm-mama~p-7999228.html
this is for rca
http://www.cablesnmor.com/rca-y-adapter.aspx
SOURCE:
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
Jan 01, 2016 | Vizio VSB210WS Soundbar
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
JVC TH-L1 problems....no sound
Almost the same problem. HDMI connections good, sound and video through monitor (LCD TV) , but no sound from the JVC unit speakers.
Dec 29, 2007 | Audio Players & Recorders
Vizio High Definition Sound Bar Logo
777 people viewed this question
Top Vizio Audio Players & Recorders Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
