Question about Kodak EasyShare P880 Digital Camera
Kodak EasyShare P880 not getting voice in video record mode
    New Friend:
  • 33 Answers
Hi stanleychen1,
Did you upgrade the firmware to v.1.02? This should solve this problem. The upgrade can be obtained at the Kodak support site.
Hope this helps.
Gr. Blackbear
Posted on Nov 16, 2010
SOURCE:
What size memory card can you use on a kodak easyshare p880
The P880 can use SD cards (NON SDHC) up to 2 Gb.
It supports FAT16 filesystem, so 2 Gb is the max.
If you frequently use RAW or TIFF you might want to use the fastest you can get (150x)
Jan 11, 2014 | Kodak EasyShare P880 Digital Camera
I just bought a new sandisk 4GB card for my p880 kodak. Wnen inserted the new card camera screen says card is unusable, insert new card. I have followed instructions for formatting on my PC, but still get...
The P880 works with MMC and SD cards. Your new 4GB card is an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. The camera is limited to working with cards 2GB and smaller.
Sep 01, 2011 | Kodak EasyShare Z710 Digital Camera
My Kodak easyshare p880 will not turn on. It works when switching to favorites but I can not turn it on to take a picture or video.
Go to www.dpreview.com and Kodak Talk. Search the forum for "P880 Power Switch problem".
Problem can be solved with the use of WD40. Read the solution on Kodak Talk first!!!
Hope you'll succeed!
Gr. Mart
Jan 14, 2011 | Kodak EasyShare P880 Digital Camera
Kodak P880 camera won't autofocus. I bought a used P880 - seems like an awesome mid-high end camera for someone on a budget. Problem is that it won't autofocus properly. When viewing and pressing down on...
Hi mfkcolumbus,
Did you check the firmware version? If it's not v. 1.02, then get it at the Kodak support site and flash that firmware to your camera. If it is 1.02, then you may try to reflash that same firmware. Sometimes this helps strait'n out things.
Hope this helps.
Gr. Blackbear
Jun 27, 2010 | Kodak EasyShare P880 Digital Camera
Joystick on my P880 camera is not working, it has lost its tention, it just rattles about.
You can access it by removing the case. It is held in place either by melted tabs or hopefully screws. Just remount it.
Oct 20, 2009 | Kodak EasyShare P880 Digital Camera
My Kodak P880 has frozen and will not turn on. The Firmwire upgrade was trying to run but there was no memory card installed. After that, my camera would not turn on.
Retry the Firmware upgrade.
Format the SD card in the camera afterwards.
P880 is no longer produces therefor no repair is available due to shortage of spare parts. But a Trade up option is available.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 19, 2009 | Kodak EasyShare P880 Digital Camera
No sound on Kodak P880 movies
The only possiblity you can use is do a Firmwareupdate. You can find it and an explanation how to do a Firmwareupdate here.
When this not help, it's an hardware problem and the microphone of the camera is defect. When you't lucky you can let repair kodak the camera. You should contact the kodak service to ask for repair costs, because this is a very good cam, you bought.
Aug 27, 2009 | Kodak EasyShare P880 Digital Camera
Kodak easyshare p880 camera
use WD40 or contactspray around the powerswitch after removing the battery.
then work the switch for a number of times
May 20, 2009 | Kodak EasyShare P880 Digital Camera
Try taking the battery out of the camera and clean the contacts with an eraser. Do it for the contacts inside the battery casing as well. Be sure to blow all the eraser rubbings out of the inside case and clean then off the battery contacts. Put the battery back inside the camera. With any luck, it may now work.
Jan 11, 2009 | Nikon Speedlight SB-80DX TTL Flash
Turns off by itself
I have tried numerous avenues including email solutions from Kodak and possibility of reinstalling the firmware but none worked. I fully believe the problem lies in the power switch - it is no longer making proper contact when in the on position. The only way appeared to be to have it repaired by a camera repair depot preferably one that also happens to be authorized by Kodak. The repair cost estimate given to me was $70 Canadian. Unfortunately I reported the problem after the warranty period had expired and like most corporations today, Kodak absolutely refused to foot any of the bill once the warranty period is over. I have no good reasons to keep Kodak on my list when shopping for another camera. P880 was a great camera except for the unexpected switching off and Kodak has not made a replacement camera with the same degree of sophistication.
Jun 14, 2008 | Kodak EasyShare P880 Digital Camera
Kodak EasyShare P880 Digital Camera Logo
138 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
