Question about Texas Instruments TI-89 Calculator
My TI-89 wont turn on even after I've changed the batteries twice and switched the batteries around in the calculator. occasionally, i switch the battery placings and it turns on but now it refuses to switch on at all
    Sergeant:
    Champion:
  • 387 Answers
From your description it could be the battery compartment it does not conect on the main circuit
if you can open and check the connectors it might be loose
if it will not help and you still want to fix Calculator let me know
[email protected]
Jack
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
  • 102366 Answers
SOURCE: My TI-89 wont turn of
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the diamond key. Press and hold the + key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Posted on Dec 01, 2010
I have a TI-89 Titanium but I wont turn on. I changed the internal battery and the normal battery (AAA) but still not working. Need help.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the diamond key, then press the + key repeatedly to see whether the screen darkens.
If this doesn't do it, please reply to this post and we can try other things, though they may cause the loss of the contents of memory.
Mar 03, 2011 | Texas Instruments TI-89 Calculator
It has been awhile since I've used my TI 89. It will not turn on and when I removed the batteries there was some dry build up around the ends of the batteries and along the surface. I wiped the surfaces...
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator turn on now?
Jan 21, 2011 | Texas Instruments TI-89 Calculator
My TI-89 wont turn of even after I've changed the batteries twice and switched the batteries around in the calculator. occasionally, i switch the battery placings and it turns on but now it refuses to...
Oct 24, 2010 | Texas Instruments TI-89 Calculator
I was using my ti-89 this morning and now as i try to use it wont turn on anymore i replaced all batteries but dont know why this isnt working
Sep 16, 2010 | Texas Instruments TI-89 Calculator
My ti 89 calculator wont work i changed the aaa batteries what should i do
If that doesn't do it, please append a comment to this post and we'll go on from there.
Aug 31, 2010 | Texas Instruments TI-89 Calculator
My ti-89 keep repeating the same function ! no matter what i click, it came out the same function. The only way I can do is take out the battery. Otherwise, it just keep showing me the fame function.It...
If the calculator keeps showing you the same function, you can open the Y= editor and erase the function. To turn calculator OFF, press Diamond key then ON.
Feb 19, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Can't turn on Ti-89 after not using for 5 years
Will it connect to the computer using device explorer, This way you might be able to see what the calculator is installed with. And it should turn on automatically.
Jul 01, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium
The only option or keys that will work is the ENTER key and the arrow keys. Try to get your arrow key to work by arrowing down and hit enter hopefully change you to something different.
Next, if at all possible can you hit the MODE key or get into the mode. If you get into the MODE select F3 and then arrow down twice or all the way to the bottom and at APPS Desktop select 1:OFF and then hit the ENTER key. Next, What I really think you need to do is reinstall the Ti 89 OS software. To do so you would need to connect to your computer or another Ti 89 Titanium to your Ti 89 Titanium. If you have Ti connect computer software (from the Ti site) connected to your Ti 89 Titanium it might help you more in troubleshooting any further problems too. You might be able to delete corrupt files that would free your calculator up and start running better.
Sep 03, 2008 | Texas Instruments TI-89 Calculator
Ti-89 wont turn off
I'm having the same problem:(
I need to solve this urgently, i can't stand always being removing the batteries... please help me!!!
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
246 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
