Question about Texas Instruments TI-83 Plus Calculator
TI-83 Plus completely blank and won't turn on. All batteries are fine.
  • 4 more comments
  • kakima Oct 25, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
  • cathydelaney Oct 25, 2010
    Nothing happens with those keystrokes either.
    Next step: Remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries. Does the calculator turn on and work normally now? You may have to adjust the screen as described earlier.
    That did not work either.
    Has the calculator been used recently, or has it been sitting for a long time with the batteries in it? Make sure the contacts are clean and free of corrosion.
    Are you using alkaline or rechargeable batteries? If you're using rechargeables, try a set of alkalines and see whether the higher voltage makes a difference.
    It may have sat for along period, but my son replaced the batteries. The contacts are clean. I checked the voltage of the CR and it was 3.38 V. I think I checked the AAAs and they were above 1.5 V on Friday. They are alkaline, but now are down to .9 V. I just put in a set of AAAs measuring over 1.5 V and still get no response. Did the the clear drill too. Now I'm wondering if something could be drawing down the batteries.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Posted on Mar 03, 2011
SOURCE:
New batteries and won't turn on
You might want to check the batteries, and make sure that they're in the correct way. If they are, then you either purchased bad batteries, or your 83 suffered a catastrophic failure/broke
Aug 19, 2011 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus "waiting ...please install message then "error message
Please Install Calculator Software Now error
This message means that the operating system has been corrupted. These steps will allow you to update the OS.
Unit to Unit
• Connect two TI-83 Plus units by means of the data cable (short black cable that was prepackaged with the TI-83 Plus)
• Make sure that at least one of the TI-83 Pluses contains the current Operating System
• Select [2nd] Link
• Select "Send OS" option from the Link menu
• Make sure that the other unit still reads "Waiting Please Install"
• The OS should be downloading.
From the Computer
• Make sure you have the latest version of the TI Connect™ Software
• Download the latest version of OS for the TI-83 Plus to the desktop of the PC.
• Connect the appropriate TI-GRAPH LINK™ cable between the PC and TI-83 Plus.
• Since the TI-83 Plus is currently off, the TI-83 Plus will automatically turn on when the TI-GRAPH LINK Cable is inserted.
• On your computer, choose Start, Programs, TI Tools, TI Connect, TI OS Downloader.
Dec 10, 2007 | Texas Instruments TI-83 Plus Calculator
My Ti-83 Plus won't come on. The screen is blank. I have just put new batteries in it. What could it be?
If that doesn't do it, remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. The calculator should come on (you may have to adjust the contrast as described earlier).
Aug 24, 2010 | Texas Instruments TI-83 Plus Calculator
Screen went blank replaced AAA batteries starts up
You may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Oct 25, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 Plus Calculator will not turn on
This is from TI FAQS:
Solution 11900: Troubleshooting a TI Graphing Calculator That Will Not Turn On.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 06, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Use a paperclip (tiny hole on back of caculator) and reset.
JC
Sep 16, 2008 | Texas Instruments Office Equipment &...
Texas Instruments TI-83 Plus Calculator Logo
378 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
