Question about Apple iPhone Smartphone
While I was texting my friends I had a low battery and my phone shut off. Now no matter what I do the phone shows rge connecting to iTunes screen. I am currently away and do not have access to a computer but any advice will help thank you.
    New Friend:
  • 11 Answers
Many people face this problem change your iphone
Posted on Oct 24, 2010
SOURCE:
Why does my iphone 4s keep randomly shutting off?
the problem may be from the battery... you can ask an expect to check if your battery...
Jul 15, 2014 | Apple iPhone 4S
How to recover iPhone messages?
To my knowledge, you can use the iOS Data Recovery to help you recover the deleted text message.
How to Retrieve Deleted Text Messages on iPhone 2018 update
May 06, 2014 | Apple iPhone 5S
Cant update my iphone 4 (model mc609ll )
Perform a recovery-mode restoreIf your iPhone, iPad, or iPod touch is already showing the "Connect to iTunes" screen, please go to step 5.
  1. Connect your USB cable to your computer but not to the iPhone, iPad, or iPod touch until step 3.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button down, connect the USB cable to the iPhone, iPad, or iPod touch. The device should turn on.
  4. Continue holding the Home button until you see the Connect to iTunes screen. When this screen appears, you can release the Home button:
    Note:
    If the image of a battery appears, let the device charge for at least ten minutes to ensure that the battery has some charge, and then start with step 2 again. If you don't see the Connect to iTunes screen, try these steps 1 through 4 again.
  5. iTunes should automatically open and display the following message:
    [img alt="Alert text: "iTunes has detected an iPhone in recovery mode..."" width="520" height="241" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1808/HT1808--recovery_alert-002-en.png" data-hires="true">
    "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
    If iTunes not open after two minutes, please open iTunes yourself.
  6. Use iTunes to restore the device.
Sep 21, 2013 | Apple iPhone 4 Black Smartphone
Nokia 5800
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPhone 4S will erase everything on it, so make sure everything on the iPhone 4S is stored elsewhere prior to restoring. To restore, connect your iPhone 4S to a computer with iTunes installed. Click "Restore" on the iPhone 4S summary page (click on your iPhone icon on the left menu to find this page). Follow the directions to restore. If your iPhone 4S displays the text "Please wait. Very Low Battery," leave it plugged in. This charges the iPhone 4S enough to be able to restore. If the iPhone 4S hangs on this screen for long periods of time, you may need a new battery.
Force restore mode
If your iPhone 4S is hanging with an Apple logo, or exhibiting some other software problem that prevents iTunes from recognizing it, you can force it into recovery/restore mode and then use iTunes to restore the software.
If the device is powered off, plug one end of your USB cable into the iPhone 4S and leave the other end disconnected. Press down on the Home button, and keep holding it down while you plug the USB cable into your computer. After 5-10 seconds, you should see a "Please Connect to iTunes" image on the iPhone 4S, and iTunes should prompt you to restore the software; follow the prompts and the instructions given above.
If the device is powered on, hold down both the power and home buttons until the device reboots and displays the "Connect to iTunes" image (generally, 5-15 seconds).
proceed with steps and fix it.
God bless you
May 31, 2013 | Cell Phones
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
A1303 34gb won't restore in itunes
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 30, 2012 | Apple iPhone Smartphone
I restored an iphone 3g via itunes and then tried to start it. it is stuck in emergency mode and shows the itunes connect logo's and at the top of the screen there is a lock logo in a locked position....
Sir,
Your phone is locked kindly go to the mechanic and opened the lock , if your cell phone is unlocked then only you can use other wise your phone is gone bad
May 20, 2011 | Cell Phones
Phone's screen won't turn on
Fist off i have to ask what Generation Iphone do you have? and is it haxed? if it's not haxed then try this, hold the phone under a lamp, not to close though. Call your Iphone and try tilting you phone at an angle to see if you can see the screen to answer the call. Your brightness settings may have gotten adjusted so low that you cant see anything. I have seen this happen before. If you plug it in to your CPU will it light up and show the charging icon? If not then you are going to have to hard reset the phone, this sucks i know but the phone is usless right now anyway. And you can just resync it with Itunes after. Hope this helps, Cali
Jul 25, 2009 | Apple iPhone Smartphone
Samsung sgh-a707 won't stay on. Shuts off when batt seems full.
try to go to a local store or through your service provider to run a test on the battery that you are using. It might be defective, tyr using a different battery for the phone. If using a different battery would not resolve this issue, it means that the phone needs service.
Jun 27, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
Apple iPhone Smartphone Logo
29 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
