Question about Samsung Glyde SCH-u940 Cellular Phone
How do i reset my phone? i accidentally switched the nam for nam1 to nam2 and it wont let me unlock it with any of my codes or my last 4 digits
    New Friend:
    Problem Solver:
  • 5 Answers
Http://www.youtube.com/watch?v=hz-oPn1yTuo
Go here this is how i fixed it
Posted on Nov 08, 2010
SOURCE:
I changed my nam on my g'zone and now im locked out of my phone
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Casio Cell Phones
When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
I have a samsung reality. i was fooling around with the settings & set it to NAM2. it's now locked i need a 4 digit code. i've tried all the online suggestions nothing works. i've been up for 4 hours...
Using the default "last four digits" unlock code will not work because switching to NAM2 changes your phone number, and hence changes the default unlock code. You have to find out your new phone number (and new unlock code) under NAM2. Do this:
  • Get to the dialer screen.
  • Dial #43574357* (#helphelp*)
  • Tap "1. system info"
  • The top two entries, MIN and MDN are your new number. Usually they are invalid phone numbers (000-000-????) but the last four digits are your unlock code. Write them down or remember them.
  • Get back to the unlock screen, type in the code.
  • Go directly into the menu and change back to NAM1
  • Don't do that again. :)
Sep 17, 2010 | Cell Phones
Ok i changed my phone system to NAM2 from NAM1 and i cant unlock the phone
try the instructions from this URL...It worked for me.
http://www.blurtit.com/q1652331.html
Dec 28, 2009 | Samsung SCH-u540 Cellular Phone
I recently switched my NAM for NAM1 to NAM2 at first everything was fine it rebooted and everything but at start up it asked me for a four digit unlock code i was like what the heck i dont have an unlock...
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Oct 20, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
Jul 06, 2008 | Samsung Glyde SCH-u940 Cellular Phone
Casio gzone
i set my boulder to nam2 on accident and my code didnt work after searchin for like 4 months on the internet i found this code ##7764726 (PROGRAM), SEND. SPC Enter 000000 after u enter it go to the nam settings select nam2 go to the second one its like MDN or somethin like that the last four digits should unlock it but u might have to take it to the store to get it programmed again but ull have ur phone back without losin any info u mightve saved on it
Dec 05, 2007 | Casio G''zOne Type S Cellular Phone
Samsung Glyde SCH-u940 Cellular Phone Logo
331 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
