Question about Garmin zumo 550 GPS Receiver
No road maps ( Zumo 550
Unable to Calculate Route: No roads near starting point.
I have downloaded software that came with my Zumo 550 went to
web user too, to down load other info from Garmin.
Reset to factory spects..... did the little black dot touch drill.....
sure could use some ideas here.... rather not wait until Monday to call a tech...
  • 174 Answers
Do you see a map, with street detail? Any SD card installed?
Tap the wrench symbol, tap mapping, tap about, any maps checked? if not, check the apropriate map and go back to the map screen
Posted on Jun 09, 2008
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
I have lost all my maps on m garmin nuvi 880. When I select one of my favorites it displays route calculation error. no roads near starting point. Also the display screen does not show any...
Try connecting it to your computer via a USB cable. Then log on to Garmin's webiste and download a map update. Then you can put the map update on your GPS to replace the ones you lost. All Garmin customers get one free map update. After than it's about $40-$60 dollars for an update.
Mar 05, 2011 | Garmin nuvi 880 Car GPS Receiver
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
No data available and no maps downloaded
it may just be that the maps are deselected. to correct this go into the tools/settings/map and then at the bottom of the screen in the middle you will see map info tap that and then at the next screen it will show you the maps which are installed if there are any without ticks just tap the box. tap ok and try again if. if there are no map choices then you will need to reinstall the maps on your unit
Apr 26, 2010 | Garmin nuvi 780 GPS
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
Etrex Vista HCx will not calculate routes.
Please post the co-ordinate of the starting waypoint and I'll check it with mine.
Aug 12, 2008 | Garmin eTrex GPS Receiver
Garmin 660
Have you updated the software since you purchased the unit? If not, go to Garmin's site, download WebUpdater and check to see if there is an update to the unit's software. If so, download this and see if it helps. If not, try downloading the same version of the software again. This might help also.
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Lines Running North and South
How do you load maps? and are these Garmin maps. I try to keep the Zumo original and use an SD card for extra maps. Did you try this yet? And if you are using SD cards, try a different brand/quality. I had some lockups with crappy budget cards. Kingston, Sandisk and some other A brands work fine!
Oct 16, 2007 | Garmin zumo 550 GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
429 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
