My computer sound driver does not work - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
You might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Posted on Oct 24, 2010
SOURCE:
No Audio on Computer
your system need sound drivers and after install you check sound is working absolutely :) you find driver from drivers.freesoftz.com
Jan 10, 2012 | Computers & Internet
Just bought new speakers i know they work. but the sound through my computer does not work even through head phones. how do i fix this?
Check your computer if the driver of your sound card is installed by play a music/mp3 in your windows media player if no error your sound driver is installed already...if there is a error installed first your sound driver...you can check also your speaker to another computer with installed sound driver, if this working...your computer have a problem with your sound driver..
Mar 05, 2011 | Acer AX1200B1781A / AX1200-B1781A /...
No sound device found on my dell b130 ?? Went to dell website still can't figure it out. I am not a computer gurro. When I did a system restore/set point it wiped out my sound
probably you restored to a point when the sound was not installed yet or damaged..You need to reinstall the sound driver and it will work ..If you have a disk with the drivers .select the sound driver for teh operation system you use and install it from the disk ..(just double click and run the executable -install )
or ..get to the support site and under downloads , select the model ,select the operation system ...download teh sound driver ..and run it into computer ..restart and it is working
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON1300/B130&os=WW1&osl=en&catid=&impid=
Please dont forget to rate @
Jan 15, 2011 | Dell Inspiron B130 Notebook
My speakers are not working. I do not have a CD. Can I get a download?
Are the speakers themselves not working, or is the problem that the computer's sound isn't working? You can test the speakers by plugging them into an iPod or other device. If they aren't working that way either, you'll need to repair or replace the speakers.
If the speakers work on another source, the trouble is in the computer. Reinstalling the sound drivers often solves "no sound" problems. The drivers may already be in a folder on the hard disk (most manufacturers have a drivers folder somewhere). If not, you can download the drivers from the computer maker's website.
If there's still no sound after reinstalling the drivers, the sound card is bad. If the sound is built onto the motherboard (the usual case), you can install a PCI sound card as a replacement. They aren't expensive and you can find them at large retailers or online.
Good luck, and thanks for using Fixya!
Oct 19, 2010 | Harman Kardon Audio Players & Recorders
I don;t have any sound on my computer
First connect your spearker to your computer -
1. check you have installed your sound driver in your computer.
2. If there is no installed drivers install drivers from *********** board CD.
3. If you attached sound card in your motherboard, install CD which you have sound driver card.
4. Another option for drivers download from Internet and install in your PC
If not Work:
go to start - control pannel - sound & game controller - check sound balance
Feb 01, 2010 | Computers & Internet
My speakers are not working on my computer. I put
Sounds as if you lost the audio drivers for your sound card. Go into your Control Panel and call up SOUNDS. Double-click on any sound listed and see if you get an error message stating you don't have a sound card.
If that's the case, go to the website for your brand of computer and search for the audio drivers for your make and model computer.
Nov 11, 2009 | Benwin S-20 Computer Speakers
Sound on laptop does not work
HP.com support and drivers will have your driver for the sound card if its OEM with your computer. Just enter your computer modal number find the right driver and install as instructed. If you have a problem let me know make and modal of computer and sound card if not OEM. and I will try to find the driver. Please rate me mysleuth
http://www.hp.com/#Support
Mar 21, 2009 | Computers & Internet
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Jul 04, 2008 | E-Machines eMachines Desktop PC
reinstall the soundrivers from motherboard cd or download it from manufacture website
May 06, 2008 | Logitech X-530 Computer Speakers
Speakers
  1. first findout the problem is due to speaker or from your computer soun driver or hardware.
  2. for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
  3. check the computer sound driver software may installed properly
  4. for these type dxdiag on run in the start menu
  5. check the sound driver problem, if it re install the sound driver by using its cd
Jan 18, 2008 | Labtec Pulse 285 Computer Speakers
Open Questions:
BULLGUARD TeCH SuPpoRT pHoNe {^}+^/18OO8O\^\31O69^/= NuMbEr ddkkjj Usa BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
Oct 17, 2019 | Best Computers & Internet
Computers & Internet Logo
24 people viewed this question
Ekse
Alun Cox
