Question about Epson Stylus CX4400 All-In-One InkJet Printer
I need to update my printer cx4400 since i don't have a cd for this. When I purchased the printer, it's cx 5500. Why is it cx4400 now as it appears on the screen...new hardware?
  • Epson Master
  • 32,281 Answers
Normal 0
The computer does not know this model printer and gave the closest match.
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Posted on Oct 24, 2010
SOURCE:
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
Scanner doesn't work at cx 5500, i need the driver
uninstall the driver s/w of the printer compleately and restart the computer. then install the full printer s/w once again. you might be having the driver installation cd/ if not then download by going to epson site.
if things are looking difficult for you to do call epson for the support. do not take chance if you are confused and sot sure what you have to do.
May 09, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My printer has not printed black ink in months
Kindly call the Kodak helpline number again and get the printhead of the printer replaced .. Printhead will be replaced free of charge. If it does not solve the issue and your printer is in warranty,ur printer 5500 will be replaced by Kodak with an Upgraded ESP-9 printer.Even if ur printer is out of warranty,they sometime give a grace period to cx. Kindly keep me updated.
Nov 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have lost cd room to install the epson stylus cx 5500 to my computer. please help
try to use other computer that has cd room then insert your cd installer in you printer and copy the contents into your usb. Then use your usb to install that software by using usb drives.
Nov 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Lost cd to add printer
Here is a link to the software for your printer:
CX4400 Downloads
Make sure you choose the correct driver for your operating system.
When you download, the easiest thing to do is to Save the file to your desktop. Follow the setup instructions and when it call to install the software, simply double-click the file. In case you do have the setup guide, here is a link for it too.
CX4400 Setup Guide
Thanks for using Fixya.
Sep 02, 2009 | HP DeskJet F380 All-In-One Printer
Installation of cx5500 epson no installatin cd
You can get the software for the Epson Stylus CX5500 from here:
http://tech.epson.com.au/downloads/category.asp?id=styluscx5500&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2745207&sCategory1=Multi_Functional
Just choose your operating system and press Search, then Continue on the next page.
Fixya!
Chris (ziraffa)
Jan 16, 2009 | Linksys WPSM54G Print Server
How to re-connect Epson CX 5500 after I changed my hard drive.
If the technician who changed your hard drive was able to transfer ("clone") the system from your old drive, all you need to do is plug your printer/scanner in and it should work. If he was not able to do this and you have a new Windows installation, you need to use the CD that came with the printer to re-install it. Just connect up the printer to the computer BUT DO NOT TURN THE PRINTER ON UNTIL TOLD TO. Start the computer and when Windows has loaded, put the CD in the CD drive. The CD should start the installation process - just follow the instructions. If you do not have a CD, download the necessary installation software from the Epson website.If you don't know how to do this, report back and I will provide more help.
Oct 19, 2008 | Epson Stylus C48 InkJet Printer
Lost the installation cd
This is the exact link for your printer software just donwload it and reinstall it for your printer http://www.epson.co.id/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1161
Hope that helps..........
Aug 09, 2008 | Office Equipment & Supplies
Epson Stylus CX4400 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
