Question about Maytag M6X06F2A Air Conditioner
My maytag m6x06f2a-f window AC wont stop beeping
My window AC wont stop beeping when on. It beeps and says 00 where the digital display is randomly in 5 to 10 second intervals. It is driving me crazy! Any ideas? I think that maybe the timer is screwed up.
  • 5 more comments
  • Anonymous Jun 08, 2008
    My unit has the same problem and is a slightly different model:
    M7X05F2A-B.
    The beeping is driving me a bit nuts.
  • aqualover Jun 08, 2008
    my maytag ac wont stop beeping either. im pretty sure that its the timer but ive tried turning it on and off, attempted to set the timer, and tried unplugging and replugging it but nothing seems to work!
  • jpelon Jun 24, 2008
    Beeps on and off like crazy. Turns on and off. It's useless!!!!
  • Anonymous Jul 07, 2008
    After unplugging, waiting 3 minutes, and plugging back in several times it seems to have a few issues that make me wonder if the controller unit is bad.
    • It sometimes displays an EE error (this is when it shuts off right after being turned on).
    • Sometimes it will display a random number, without beeping, in the left digit but the fan continues to run.
    • Sometimes when switched on, the dispaly goes funky and cycles through a bunch of characters too fast to read, then it plays a continuous beep.
    • Other times when plugged back in, it just plays a constant beep
  • Anonymous Jul 08, 2008
    same problem with mine. had problems with every maytag applaince i've owned
  • Cadillacmac Jul 16, 2008
    Turned the unit off and on
    Unplugged it
    Changed the mode
    Changed the temp
    Checked filter
    Changed the timer setting
    Cursed
  • Anonymous Jul 31, 2008
    same thing
We had the same problem and changed the setting to auto and the unit seems to be working properly now. Not sure if this solves the problem, but for the past 1/2 hour the unit has stopped jumping between 00 and the temp we set.
Posted on Aug 11, 2008
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Maytag oven manual
YOu are most likely having a temp sensor failure, an exact model number would be needed for further diagnosis. Are you also getting an error code in the display? Pleazer Appliance...
Apr 19, 2014 | Kitchen Ranges
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Timer for Maytag 8000 btu digital window air conditioner If i put my ac on a timer (it doesent have a built in one) it wont turn on unless i press the on button. Is there anything I can do to get it to...
Not much you can do with it being a digital control ,power needs to stay on all the time. There are ways around it but it is a chore re wiring to make it work.
Aug 19, 2013 | Maytag M6X06F2A Air Conditioner
A6x06f2a
Unplug it for a few minutes and let it reset
Jun 08, 2013 | Maytag M6X06F2A Air Conditioner
Taylor 1431 Digital Wireless Thermometer beeps at random intervals. Is there a way to silence it?
yes there is a solution to stop the beep. Take a piece of cotton and put into ur ears..... simple
Jul 05, 2011 | Taylor 1431 Digital Wireless Thermometer
What is the amps for a Maytag window air conditioner model#M6X06F2A
The label on the AC should tell you the ratings in Watts. Divide the watts by voltage to derive amps. Hence 7400 watts @ 240vac would be 30.8amps
A quick search on the internet shows that your unit pulls 618 watts while cooling and is designed for 115vac. So @110vac that is 5.6amps and @120vac that is 5.1amps... See why voltage is important?
Jun 14, 2010 | Maytag M6X06F2A Air Conditioner
Dryer randomly beeps, like morse code and changes ...
sounds like a stuck or shorted membrane switch.
which would require replacing the console. if you can access the tech guide in the control panel you can do a membrane switch test and other diagnostics.
May 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Maytag M6X06F2A Air Conditioner Logo
1,463 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
