Question about Polti Eco Pro 3000 Canister Steam Vacuum
I have a Polti Vaporetto household steam cleaner that I bought 16 years ago. I haven't used it for about 10 years because the connection between the steam er and the attachments doesn't work properly and it is difficult to use. The shop where I bought it no longer sells them and can't get them fixed anymore. I'm about to ditch it, but thought I would have another go at using it. (It was very expensive). Now I can't get the safety cap off so I can't fill it or test it. Any ideas on what I can do or if there's anywhere in Sydney I might get it fixed?
4 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Posted on Mar 11, 2008
Ranglo
  • 1194 Answers
SOURCE: lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
Posted on May 31, 2010
SOURCE: my polti vaporetto 2300 is belching with
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Posted on Mar 09, 2011
Lost instructions for vaporetto polti 2400
Good Luck
May 31, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Due to illness etc I've not used my Polti 2400 for a couple of years. Now I want to use it I have all the paperwork that came with it - except the instructions! Can you help.
Polto steam cleaner 2100/2400 yellow, the on switch will not click on so the water does not heat up. The orange light comes on when i press the on switch but goes off and the button comes back up as soon as i let go. Any ideas will be gratefully received.
Dave
Mar 14, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
How do I undo the torx screws that hold the Polti 2400 Steam Cleaner (Polti Vaporetto 2400) together? There is an electrical fault and I will have to strip it down to investigate.The house RCD trips when...
With a torx screwdriver! There's nothing special about these screws except the shape of the hole in the head. Commonest size in small domestic machines is T15.
Oct 15, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
No steam from my almost new Polti 2600
It sounds like the solenoid isn,t activating when you pull the trigger which then lets the steam out. It either wants stipping and checking or returning to where it came.
Apr 19, 2009 | Polti Vaporetto 2000R Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Eco Pro 3000 Canister Steam Vacuum Logo
81 people viewed this question
Top Polti Vacuums Experts
Tom Chichester
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
