Forgot my password on my wireless router TP-Link
    Habit-Forming:
  • 144 Answers
Step 2 Turn off the router (pull the power out of the unit). Step 2 Press and hold the reset button on the rear panel with a pin, while holding down the reset button turn on the router (plug the power back into the unit). It is important that you continue to hold down the reset button for approximately 15 seconds. Step 3 Release the reset button and wait for the device to reboot.
Posted on Oct 25, 2010
SOURCE:
How do i change password for tp link wr741nd
If it's the security key just login to the router and change the password. If it's the password to login to the router UI you will need to reset the router to factory settings.
Mar 07, 2015 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
I have forggotten my wirless password
You can reset the wireless router back to the defaults.
For details refer to the manual.
You can download the manual from this WEB site.
http://www.tp-link.com.au/resources/document/TL-WR741ND_V4.20.0_User_Guide.pdf
Apr 05, 2013 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
TL-WR940N
Hello
I can give some details on port forwarding for TL-WR940n. You could follow this procedure given below. here is the link too. http://www.tp-link.com/en/article/?id=72
How do I open ports on my TP-LINK wireless Router?
Suitable for: 300Mbps Wireless N Routers, 150Mbps Wireless N Routers, 54Mbps Wireless G Routers
Step 1 Open the web browser and type the IP address of the router (default is 192.168.1.1 or 192.168.0.1) into the address bar and then Press Enter.
Step 2 Type the username and password in the login page, the default username and password both are admin.
Step 3 Click Forwarding->Virtual Servers on the left side, and then click Add New... button.
Step 4 Type the Service port which you want to open and the IP Address of your computer; Select Protocol to TCP, UDP or ALL; Change Status to Enabled
Step 5 Click Save button to save the settings.
Note:
If you want to open port 80 for Web server in your computer, the Management port of the router will be changed to 8080, you need to type Http://192.168.1.1:8080 to connect to you router.
TP-Link_SupportForce
TP-Link USA Corporation
Tel: +1 866-225-8139
E-Mail: [email protected]
Website: www.tp-link.com/en/support/index.asp
Jun 08, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
In my device wirless strangth singal led is not power on. pls give me solution(TP-Link) TL-WA5210g
http://www.tp-link.com/en/support/downloadFiles.aspx?mid=01030301&version=V1&pmodel=TL-WA5210G
Seems a problem with the firmware. Double check if your product is the same as the link above and apply the fix described in the support page.
Top firmware version 09/30/2010. this firmware version will include the previous fixes like LED is not ON. Download the file decompress and execute. Please use a wired connection (CAT5/6 network cable) between your computer and the outdoor device. Do not use the wireless connection and be sure that both devices (source computer and destination AP/router/wireless TP device are powered up at mains (no batteries). Back-up yor settings as a firmware update is possible to erase all your settings.
A bit of trivia:
Your wireless outdoor device is decent but not "50km". For that you need a big comms tower.
Good luck.
Jun 29, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
How to change password on the router TP-LINK
try to access your routers GUI by typing 192.168.0.1 or 192.168.1.1 in your internet browser.then you go wireless then wireless security. now change your password then save.
Apr 13, 2011 | TP-LINK 11G Wireless Adapter
I wish make password for my wireless router my TL-link is TL-WR542G I havnt password before thak you
download the manual from here
http://www.tp-link.com/support/download.asp?a=1&m=TL-WR542G
it will tell you how to set it up for wireless security
Feb 13, 2011 | TP-LINK TL-WR542G Wireless Router
Trying to secure my tp link router
You need to access your router setup and admin pages.
At START, RUN, type in CMD. This will open DOS dialog box. at the >prompt, type ipconfig. Look at the data returned, Your are looking for the Default Gateway. It will be like 192.168.1.1 or some other sequence.
in your browser's address bar, enter this number. This opens the router set up/admin page. default login should be user:admin, password:admin.
I don't have the model number of your TP Link router. Find yours at TP Link. You need to change your Newwork name (SSID), your user name and your password. Change also your wireless security to WEP.
All of this should be in your manual or on line.
The picture below shows the WEP change.
Good Luck
Feb 01, 2010 | Computers & Internet
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
Jan 07, 2010 | Computers & Internet
Clarification on the router configuration
The defaults are:
username: admin
password: admin
To reset, hold the reset button for 10 seconds without powering off.
Here's the website, just for future reference:
http://www.tp-link.com/support/download.asp?a=1&m=TL-R402M
Hope this helps
Chris (ziraffa)
Jan 17, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Computers & Internet Logo
1,555 people viewed this question
Ekse
Alun Cox
