Question about LG DBRH197H DVD Player/HDD Recorder
I have an LG 42LB1DR TV with the built-in DVR. I have had the power supply replaced once, and just had to replace the usual 5 faulty capacitors again -- this time I used ones with higher temperature & voltage ratings. Now the DVR is starting to act up, frequently requiring the set to be re-booted (full power cycle using the cord) in order to get the drive to work, and occasionally requiring a re-format. :-( The set is 4 years old, and this is the first I've seen of this problem. Is this likely to be a disk problem or a logic board issue? If hard-disk, what models can be used as replacements? I wanted to upgrade to a larger disk and tried a 500GB Seagate SV35.5 disk last time the back was off, but the set didn't recognize it and couldn't seem to format it. Is there any software or anything that needs to be copied to the new disk first? Also, does anyone know what the latest firmware version is for this model? How do I get it & install it? Thanks, --Steve
  • Steve Oct 24, 2010
    I've read other posts which suggest that this may be a disk issue (and perhaps the new disk I tried is not compatible. Does anyone have further suggestions?
    How about the firmware updates?
    Thanks, --Steve
  • 11,896 Answers
Have you had a firmware upgrade done? Good fuse and clean connections?
If you can find another LG 42 series, then you can swap parts if needed.
Posted on Oct 27, 2010
  • 712 Answers
I don't think it's the hard disk causing the problem. It might be the board.
Posted on Oct 24, 2010
SOURCE:
Tv turns itself off and on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Oct 17, 2012 | LG 42LC2D 42 in. LCD HDTV
Wont turn on
Good day!!!!
Aug 26, 2012 | LG 32LF11 32 in HDTV TV
Falt screen tv has a white screen when I turn it on,audio ok,picture comes on after about 20 minutes,any ideas?
Good day!!!
Jul 18, 2012 | LG Electronics 42IN WS LCD 1920X1080...
Cuts off
Good day!!!!
Dec 02, 2011 | LG 32LG30 32 in. LCD HDTV
My LG TV 50PJ350-UB TV KEEPS POWERING OFF IMMEDIATELY AFTER I TURN IT ON
Good day!!!!
Oct 06, 2011 | LG 50PG6000 50 in. HD-Ready Plasma TV
I have a LG 42LB1DR LCD TV that comes on with picture for about 5 minutes and then the screen blanks out and the sound quits. I took the back off and blew off the heavy dust on the transistors between the...
There is 4 capacitors on the power board that need to be replaced. I have fixed 2 of these in the past now, with the same problem. They are green in color.
Oct 26, 2009 | LG 42LB1DRA 42 in. LCD Television
Lg 42lb1dr tv cuts off no picture or sound. gray screen.
There are 4 capacitors on the power supply board that need to be replace. They are in the same area, same color, look for bulged caps.
Jul 15, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42 LCD no sound or picture
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Jan 28, 2009 | LG 42LC2D 42 in. LCD HDTV
LG DBRH197H DVD Player/HDD Recorder Logo
285 people viewed this question
Ekse
