Question about Mitsubishi WD-73827 73" HDTV DLP TV
My Mitsubishi ws65737 wont turn on no light on control panel nothing
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 93 Answers
Power supply problem.....
Posted on Oct 24, 2010
SOURCE:
Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi Televison & Video
Mitsubishi wd65737 wont turn on
if you can check the power supply board look for a bulging capacitor which cause of voltage drop not to turn on the relay.
Sep 06, 2012 | Mitsubishi WD-65737 Home Theater
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi vs-50707
see a tech you need one they will come and take the panel off and thake the light box with them because you have a circiut problem
Feb 25, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Vs-55707
Press Input and menu together on the TV control panel and hold them for 5 seconds see if it blinks a two digit code.
Oct 31, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Just got it (used) power problem?
  1. turn your tv on with remote control
  2. go to menu select front button lock
  3. select off to restore the operations of the front panel operations
  4. the front panel lock is a feature that lets you disable the front panel to prevent children from changing settings by accident
  5. if this doesnt work i would suggest contacting a service repair tech.
Sep 08, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Jul 04, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WD-73827 73" HDTV DLP TV Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
