Question about Sport & Outdoor - Others
Need repair or owners manual for minn kota e drive motor. thank you
SOURCE:
  • 8 Answers
SOURCE: Need wiring diagram
Call Minn kota, the number should be on the bottom of the head. They will e-mail it to you.
Posted on Nov 28, 2008
SOURCE: minn kota maxxum 74 trolling motor
http://www.minnkotamotors.com/
800-227-6433
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Posted on May 08, 2009
  • 10 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
  • 14 Answers
SOURCE: Minn Kota All Terrain 55, no drive
i would start where it plugs into the boat.check for electric there. if you have juice to the plug,then the problem is in the pedal itself.could have corrosion on wires or broken wire.you should be a ble to see which wires would be bad...
Posted on May 16, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    What is amp. draw of minn kota 40pd? thanks
    Digital Maximizer™
    Digital Maximizer™. Up to five times longer run time on a single charge.
    Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
    Pioneered in 1985, Minn Kotas innovative Maximizer™ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
    Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
    your manual is here and states it has a battery level meter.
    http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
    Minn Kota Motors
    Jan 06, 2016 | Minn Kota Boating
    Minn kota
    I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
    May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Minn-kota wiring battery charger 4 bank trolling motor e-drive
    call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
    Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Overheated Minn Kota Endura28
    This sounds like a fairly big deal. You need to check it water got into the motor. Turn it upside down and see if water comes out of the handle end of the motor. This may be a shop deal.
    May 31, 2009 | Minn Kota Endura 30 Freshwater Transom...
    I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
    Contact the people at this Email address. Minn Kota <[email protected]> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Sport & Outdoor - Others Logo
    77 people viewed this question
    Top Sport & Outdoor - Others Experts
    Marvin
    Marvin
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
