Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
My unit will not turn on
Please help me. It is so hot and my air conditioner won't turn on. I checked the curcuit brakers and it still won't turn on.
  • Anonymous Jun 10, 2008
    We've gotten a brand new machine, and it won't turn on. We tried the reset button, the circuit breaker and everything. It just won't turn on!
  • 95 Answers
It's broken
Posted on Jun 10, 2008
Kenmore Plasmaire air conditioner causes braker to throw each time it plugs in. did this suddenly after working well for months.
there has to be to much on that curcuit to run a/c. the best thing to do is have it on its own curcuit or on a curcuit where the amperage load is lighter. good-day !! this may have happened because when new, it did not draw to many amps.but with continuous use it wears on the motor etc. and is taking more amperage to run it. when I got my a/c about 4 years ago, I put it on its own curcuit. no problems yet! good-day !
Jul 16, 2011 | Kenmore 71055 Air Conditioner
Air condition wont turn on
Do you have enough power to unit? Check plug for any loose wires on unit, with unit unplugged of course.
Jul 07, 2010 | Fedders A6Y18F7BCOM Air Conditioner
2.5 RUUD AC not working, power must be getting to the unit.
Have them turn the outdoor unit off and wait a few minutes. When they turn it back on they should here
the fan and the compressor come on. They are to different sounds.
If they think that they have both come on, tell them to check the black insulated suction line. it should at least cold to the touch. If not it could be a freon issue.
If the line does get cold, have them checkthe filter in the house. If that is ok tell them to turn the power off
to the outside unit. Take a garden hose and wash
the outside coils on the outdoor unit,be carefull not to
smash the fins. Wash them at an angle from top to bottom.
Jul 05, 2010 | Ruud Central System Air Conditioner
The fan or blower motor is not turning when I switch air conditioner on.
MY AC UNITE IS ARCHING OUT SIDE THE CURCUITE BREAKER IS TRIPPING OFF
May 20, 2010 | Goodman CKL36AR36 Air Conditioner
Rheem, 3.5 ton,heating unit does not come on, main braker is at the on position,air handler comes on, is there a braker in the unit itself?
There is a red reset on the outdoor unit, near where the copper lines connect to it, also there should be fuses in the disconnect box, near the outdoor unit, that the electrician installed.
Jan 12, 2010 | Mitsubishi MS12TN Air Conditioner
Keeps on triping braker
Unit should be tested, You have a "ground fault" condition.
May 26, 2009 | Whirlwind FH-778 Air Conditioner
I own an armstrong air unit after about 30 minutes the unit seems to get hot and the fan quits the compressor is still running I changed the motor on the fan and it still does the same thing I have also...
Chech the fans rotation , the fan is suppose to blow air out the top, also if you changed the fan out ,check for the blade on right, its suppose to scoop the air from the inside and blows it out the top,, also replace the capicator...sounds to me like the motors getting too hot and tripping on internal ly high temp. Hey, slow down "Big Money"! The problem is around the fan location! Thank-you-very-much!
Aug 27, 2008 | Heating & Cooling
WHAT SIZE CURCIUT BRAKER I NEED.
If it says 70-amp, then you need all the protection it needs , when all your electrical apparatus kicks in and **** 57 amps guess what the fuse is suppose to do, blowout! NOW DO YOU SEE WHERE I"M GOING WITH THIS!
Jul 26, 2008 | Ruud UBHC Air Conditioner
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Jun 05, 2008 | LG L1004R Air Conditioner
Not working
If absolutely nothing is working, and you are getting 115v, changed the fuse, like you said. Then the problem may be the transformer.
Feb 29, 2008 | Coleman Mach 15 Air Conditioner
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
312 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
