On my laptop i have a problem with the blue screen. When I turn my laptop on it loads for a few seconds then it gives me the blue screen, what do i do?
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your motherboard to your hard drive or just replace them there probably old and faulty
hope this helps
Posted on Oct 24, 2010
6ya staff
SOURCE:
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
Laptop wont boot to windows, and flashing a blue error screen
Do a system restore/recovery to a date before this issue. Unplug, remove battery, leave battery out during this procedure, plug into AC, Start tapping the F key that will start the restore/recovery page. You didn't give OS or other info. Did you do updates? Add software/hardware? What preceded the issue?
Nov 29, 2012 | Computers & Internet
Using Windows 7, relatively new HP Pavilion dv7. About a week ago a Memory Dump blue screen started appearing spontaneously, would stay on for only a very few seconds, then restart the computer. There...
hi
memory dump is the result of bad memory module (RAM).. remove the ram modules, look at them, make sure they are same make and part. different manufactures can often cause memory fault in a system
if that's the case, replace the memory modules . you can go to the link below and select the model you have, go to KEYWORD selection, and select MEMORY DIMM, it will then give you the part number you need to replace .
if you need more help, please don't hesitate to issue 4 thumbs and i will give you further details and cost of the modules. you can easily purchase at a link i will issue at that time.
http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=49A90DD091EA4D89B2FC957BD1525074&SearchCriteria=dv7t
please issue 4 thumbs up
Jan 07, 2011 | HP Pavilion dv7t PC Notebook
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Acer travelmate5720 fat32 problem blue screen
Sounds like the hard drive is starting to fail. Do you hear and occasional 'click-click', 'click-click'?. A new hard disk should solve the problem
Jul 23, 2009 | Acer Aspire One PC Notebook
I get a black screen saying windows cannot load
Are you able to boot in safe mode?
Are you able to boot from cd?
you may have to reinstall windows.
May 10, 2009 | Acer Aspire One PC Notebook
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
Feb 15, 2009 | Acer Aspire 5520-5908 Notebook
Black screen, won't boot up, fan kicks on for a few seconds only, then powers down
check the display on the external monitor through the vga port, if the display is fine , then its the problem of your laptop screen, some time this is due to the cable that gives display to the screen, take it to the technician and checks there
how do you like the solution rate it please
Oct 17, 2008 | Toshiba Satellite M35X-S109 Notebook
Open Questions:
Computers & Internet Logo
83 people viewed this question
Ekse
Marvin
Marvin
