Question about Car Audio & Video
Wiring diagram for 1992 mitsubishi lancer - Car Audio & Video
SOURCE:
Molson02536
  • 3854 Answers
SOURCE: I hae a 2002 mitsubishi lancer I need wiring
Here is a link that should help you get the wiring colors you asked for. Good luck and hope this helps. http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Posted on Oct 28, 2009
  • 96 Answers
SOURCE: I hae a 2002 mitsubishi lancer I need wiring radio
i dont have a pic but it goes like this..
(color1/color2 usually means the wire has a stripe or dots on it)
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
WellyTurbo
  • 19 Answers
SOURCE: I have a Mitsubishi Lancer Hatchback 1992 model
be the torque converter im guessing dude, basically a clutch on a auto.
Posted on Jul 19, 2010
kapishtech
  • 2272 Answers
SOURCE: How do I change a alternator on a 1992 mitsubishi
The procedure is as follows:--
  • First of all remove the negative connections on the battery and positive connections of the battery.
  • Then lift up the Lancer using the jack and put it down on a pair of jack stands.
    Unbolt the passenger side cover panel from the bottom of the car using the 3/8-inch ratchet and socket. Locate the tensioner on the center of the engine. Mount a socket onto the breaker bar and turn the tensioner to relieve tension on the belt. Pull the belt off the alternator pulley.
  • Unbolt the electrical connections on the alternator with an open-end wrench or a 3/8-inch ratchet and socket depending on accessibility. Unbolt the water pump pulleys from the water pump using the 3/8-inch ratchet and socket.
  • Unbolt the alternator from the engine using the 3/8-inch ratchet and socket. Then lift the alternator away from the engine compartment.
  • Now in the same way place the new alternator in same position and refit it in reverse method. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Posted on Aug 18, 2010
    micromatikal
    • 2777 Answers
    SOURCE: where can i find a
    You will need a wiring hardness, which comes with the diagram for your model. It depends on which stereo you wire it to from there, but you can go to any car audio shop and get a wiring harness including the diagram you need. They are different for each harness, but it will include it.
    Tim
    Posted on Sep 25, 2010
    Lancer stereo wires
    Hello Nacomi Campbell,
    Here are two FREE SITES with decent audio wiring diagrams
    For serious ELECRICAL QUESTIONS...
    I always recommend QUALITY DOCUMENTS ... Typically:
    FACTORY WORKSHOP Repair Manuals
    Else...
    for USA Market vehicles:
    Check for your models FREE WIRING DIAGRAMS & TECH SERVICE BULLETINS at BBB Industries site
    (registration required... real documents) ... and
    Crutchfield
    BBB Industries
    BBB Industries Premium Alternators Starters Power Steering Products
    Crutchfield (live on-line assistance)
    Shop Factory Radio Improvement
    Hope this helps... Happy (FREE) hunting
    Jan 25, 2017 | Mitsubishi Cars & Trucks
    Wiring diagram of mitsubishi lancer 4G18 2003
    Wiring diagrams are broken down into systems like lighting, engine etc. What system do you need a diagram for??
    Mar 11, 2016 | 2003 Mitsubishi Lancer
    You will see my problem in the picture I need these the fuses for my Mitsubishi Lancer 2005 can you please help and tell me what they are
    Google Mitsubishi lancer 2005 wiring diagram
    click on images across the top and it will show you all the wiring diagram
    select one and go to fuse box
    all the info will be there
    Hope this helps Mike
    Feb 27, 2016 | Mitsubishi Cars & Trucks
    Engine wire harness diagram for 2002 lancer oz rally
    I am really impressed in your blog.....and Thank you for sharing this information...It is Very interesting..<a href=" http://www.pcmofnc.com/"> Trailblazer SS parts</a>
    Nov 11, 2013 | 2002 Mitsubishi Lancer
    Mitsubishi vacuum diagram
    hello
    please answer me to [email protected]
    i have mitsubishi lancer with 4G13 motor and sndlw body (1992 year)
    the carburator is single(is not electrical) the all hoses are moved and i dont now how to fixe them please help me for a plan or map of hoses of carburator(i am teacher in iran i can buy a lancer 1992 after 29 year teaching do you beleave this this is iran)
    thanks
    Aug 04, 2012 | Mitsubishi Cars & Trucks
    Mitsubishi Lancer Need fuse box diagram, which fuse is what. My son bought this car and the owners manual was missing and he is having trouble figuring out which fuse works what. Thank you for the...
    The Mitsubishi Mirage is a subcompact car produced by Mitsubishi Motors from 1978 to 2002. It was also sold as the Mitsubishi Colt or Lancer.
    The following wiring diagram and electrical circuit/schematics manual provide detail information about the electrical system description, illustration and troubleshooting of Mitsubishi Mirage 1999 models: Mitsubishi Wiring Diagram
    Hope helped.
    Oct 16, 2009 | 2002 Mitsubishi Lancer
    Wiring a radio
    here is the wire diagram for your car this should fix your problem
    Sep 16, 2008 | 2002 Mitsubishi Lancer
    Car Audio & Video Logo
    343 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
