Microsoft Windows XP Professional for PC Logo
Posted on Jun 07, 2008
Winsys32 problem dear problem solver, when i switch on my comp, after the booting process when it reaches to the desktop, the first msg it shows is like 'specified path name of winsys32 could not be found.' Let me tell you one thing more, i have had internet installed just a week back, and this problem has surfaced only after when I updated the avast antivirus software. It has barred the access to many a files mostly .exe ones. This has also led to slowdown of my PC. Kindly Suggest me what to do????
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
512
Points
5
Ok..
First try to Restart the computer in Safe Mode to narrow down the causes of the Problem.
To get into Safe mode - Restart the Computer and immedietly start tapping F8... You will get the "Windows Advanced Options"
Screen
Select "Safe Mode"
Check if you get the error or not
Anonymous
Level 1:
  • Contributor 25 Answers
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
4499
Points
32
Try rebooting int SAFE MODE or last known good profile. Once able to login, just undo the changes made. You can recopy the setup files using windows CD update. If nothing helps just mail me.
Gateway desktop cop. DX4860 : Start switch on light is not lit steady, it is flickering, the comp. running without any problem.
This means it is processing, if the light stops, you are in trouble. If it annoys you, cover the light with something....maybe put a cup of coffee infront of it! :)
I have a gateway mx6214 dont have org recvery cd, had msg system32 config system with blue screen my frnd had an older verison 1yr older of gateway recvery cd tried 2 load tht thn i got a new msg windows...
On first Boot press F8 repeatedly >> next it will shows some lines >> choose SAFE MODE >> ENTER
If you can log on > its mean something wrong with some drivers or applications. try uninstall recently installed applications or driver >>> Uninstall it on control panel > add/remove program
akee.4shared.com
"NTLDR IS COMPRESSED PRESS CTRL+ALT+DEL TO
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
1helpful
NO POWER
If you have changed the power unit and the computer is still not powering up, then it is quite likely there is a motherboard fault - probably in the power management circuitry, which expects the power_good signal from the power unit at a precise moment in the boot up process. A fault in the power management circuitry would prevent the computer from beginning its boot-up process.
Do the fans in the power unit come on when the computer is switched on? If they don't - this suggests a power unit problem. If the power unit fans do start working but the computer still doesn't boot, this suggests either a faulty or 'dry' connection (easy checked) or a motherboard fault.
If your computer 'works' but nothing is displayed, try pressing Control+Alt+Delete. If it then boots up it suggests a power unit problem. If not .. we come back to the motherboard again.
A low wattage power unit can cause the problem you describe. Every 128 Mb of Ram needs 4 watts of power. Add more for the motherboard (up to 30 watts..) then the floppy/hard drive/dvd etc .. If the power unit can't supply the necessary wattage, it won't boot. The older 250-300 watt power units aren't suitable for modern computers with XP/Vista. Ideally, you should be looking at 400 watts plus -it will tell you on the power unit.
Though to be honest, it does sound like a motherboard fault.
The only other thing that can cause a computer not to boot up (though it will begin the boot up process) are other faults ... When you switch on does it actually display anything on the screen .. and are there any 'beeps'? 1 beep indicates everything is ok .. 3 short beeps and 1 long beep indicate a memory problem (and the computer won't boot..). 8 beeps indicate a video problem (and nothing will be dislayed on your screen). Same with 9 beeps .. which indicates a bios fault - and the computer won't continue the boot process.
If you have nothing .. no power whatsover ... it comes back to the power unit/mainboard. If you're happy that the new power unit you have put in is ok ... suspect the motherboard. If you have access to any unwanted or 2nd hand motherboard ... connect that. If your computer boots up ... its the original motherboard at fault.
Alternatively, rather than replace bits and pieces at random to cure the fault, take your computer along to a computer shop. It will take them minutes to test it for you and identify the fault.
2answers
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
3answers
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
