Lamp and power button are flashing very fast - Televison & Video
  • 5,138 Answers
You need to Post TV Make and the Model# printed on back?
Posted on Oct 24, 2010
SOURCE:
I tried to program a new fob for a 1999 Altima. And nothing worked
1.   Close and lock all doors with the driver’s side power lock/unlock switch.
2.   Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3.   Insert key into the ignition cylinder and turn to the ACC position.
4.   Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5.   If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6.   Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
Make sure you have the right fob for your car.
Nov 15, 2016 | 1999 Nissan Altima
Mitsubishi WD-62525 3 fast red lights then 1 long repeating
Not sure if they can be swapped out....you may want to get the schematics or service manuals and check
Apr 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
The interior lights will not come on when door opens, the visor lamps will NOT light no matter what, radio lights work normally the turn signal lamps blink fast, but all bulbs light
For the turn signal flashing fast - MAKE SURE you have all bulbs flashing that are SUPPOSED to be flashing. The front side marker lamps are part of this equation.
As for the interior (dome and visor) lamps, there is a fuse labeled "CTSY LAMP" in the fuse block. The lamps themselves are controlled by the body control module (BCM). The CTSY LAMP fuse only provides input power to the BCM. I would start with a scan of the BCM to see if it can shed any light (No pun intended) on your problem.
Dec 01, 2010 | 2000 Chevrolet Venture
Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Acer AL1916B 19" LCD Monitor
My infocus PL70+ powers up but there's no picture. after I plug in, the amber light come on so I hit the power button, green LED light flashes, fan kicks in, green LED remains steady after flashing for a...
if you hear chirping or a loud buzzing, you have a bad colorwheel. the lamp won't turn on if the colorwheel doesn't spin as fast as it needs to. if you don't hear anything like that, you need a new power supply. the lamp striking takes a lot of power, and if the power supply can't handle it, it shuts off. you can get the part from an infocus service center and replace it yourself, or send it to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 12, 2010 | InFocus LP70+ Multimedia Projector
Hi I want to program a new keyless fob. I have the original fob that works great.Do I need to do anything to the original key when I program the new fob? 2006 nissan altima
Nov 16, 2009 | 2006 Nissan Altima
Set keyless remote for Nissan xterra
I AM TRYING TO PROGRAM MY RCR311B TO OPERATE MY TOSHIBA TV CAN YOU SEND ME INSTRUCTIONS
Jan 20, 2009 | RCA RCR311B Remote Control
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Panasonic PT-50L14 50 inch will not turn on.
i looked at a copy of you owners manual, look at page 97 to 100. I suspect the red blikning light is the lamp led. if it is i suspect a bad lamp. the lamps are customer replaceable. page 98 show how to replace the lamp. unplug the tv & remove the lamp, look at it to see if it is damaged (inside the lamp is there any broken pieces of glass?) lamps are around 150.00 to 500.00. good luck.
Dec 07, 2006 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Ekse
