Question about Toshiba Satellite P105-S9722 Notebook
MY MOUSE PAD FREEZES UP OR MOVES AROUND ERRATICALLY WHEN COMPUTER IS TOO HOT HOW OT FIX IT?
  • Toshiba Master
  • 27,725 Answers
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
and buy yourself a laptop cooler with built in fans
hope this helps
Posted on Oct 24, 2010
SOURCE:
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Dec 29, 2013 | HP EliteBook 2730p Tablet PC
Erratic cursor ms media centre wireless keyboard
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
Dec 28, 2013 | Computers & Internet
Acer aspire 5520 mouse pointer problem it freezes or moves around the screen by itself
Glad to HELP YOU!
First of all try to clean your touch pad with a SOFT CLOTH gently soaked in a GLASS CLEANER fluid. Make that as good as you can and you will remove all the dirst that may occur during the function of your computer, generating "fake movements" of the cursor.
Second: go to
START > CONTROL PANEL > MOUSE icon > DEVICE SETTINGS
and disable touch pad or check box to hide cursor while you are typing.
GOOD LUCK!
Apr 15, 2011 | Acer Aspire 5520-5908 Notebook
HP Pavilion vertical scroll bar resists pointer movement, moves erratically on its own
If you're using a ball mouse: Take the ball out and rub it on your jeans. Then clean the rollers while holding the mouse upright. Side to side motion will remove any gunk.
If you're using a laser mouse: Get a solid mouse pad. Repeating patterns (as in stripes or text and wood grain) cause mouse to get confused.
Sep 12, 2010 | HP Pavillion s7420n PC Desktop
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
.the mouse moves randomly across
If mouse is moving randomly across the screen then you may have to change the mouse or the mouse pad. If system freezes automatically that is your software problem. Please install a fresh copy of windows xp or vista whatever. Hopefully it should work . thank you.......
Sep 12, 2008 | Computers & Internet
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite P105-S9722 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
