Question about Vacuums
Hoover turbo power 3200 - Vacuums
Brush not spinning on my montiss turbo 850 vacuum. Hoover suction ok. Have took apart and deluded and still not working
Check the belt. If the beater bar will spin with the belt loose but not spin under power, the belt may be slipping.
Jan 28, 2015 | Hoover Vacuums
I want the manual for Hoover Turbo Power 3000 Bagless Model # U5349-900
you can find the manual for the hoover unit at hoover.com and click on the left near the bottom, under SERVICE AND SUPPORT it says download manuals. Click on that and it will take you to another page to insert your model number.
You may want to also double check the model number that you posted here as I was not able to find your unit.
Good luck,
Mark
Nov 12, 2010 | Hoover Vacuums
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
My Hoover Turbo has the power and motor works well but there is no suction power. I have taken all steps to ensure that there is no blockage in the pipes. I live in the Benoni area and would like someone...
remove the screws from the funny looking thing on the back (about 10 philips head screws) and remove the blockage from the big hose. Don;t stop working on it until you are absolutely certain there is no blockage. You may need a long screw driver and maybe another smaller vacum to help get the stuff out. I have the same machine and had the same trouble.
If you want to prove or disprove blockage as the trouble, remove the handle and listen to the motor.
Sep 21, 2009 | Hoover U5396-900 Turbo Power Vacuum
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
Changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Dec 31, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
