Question about Kirby Ultimate G Bagged Upright Vacuum
G5 not dispensing anytyhing
I have a G5. Everything is hooked up properly for shampoo and nothing is being dispensed out of the tube. Yes, it is in the on position. HELP
  • 357 Answers
You are missing the little screen that goes on the small hole in the tank where the shampooer hose attaches to the tank. Read this shampooing instruction guide for more info....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Posted on Jun 22, 2008
Won't dispense shampoo......cleaned it and clear water is fine. No shampoo soap dispensed?????
check the linkage between the dispense trigger assembly and the actual shampoo valve
May 03, 2015 | Vacuums
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
It is not dispensing the shampoo on to the carpet.
Firstly, please ensure that there is shampoo in the tank and the tank is correctly and fully inserted. There are 2 ways to dispense shampoo on to the carpet:
1. Use the solution trigger on the underside of the handle (numbered 2 in the picture below)
2. For tough stains use the "Clean Surge" button to dispense extra shampoo (numbered 3 in the picture below
Dec 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Kirby Shampoo system not dispensing foam
Few possible causes
1. Valve under the sponge (water tank) is clogged. Replacement HERE.
2. Tray is now lowered all the way down.
3. You use non-foamy solution.
4. Carpet is very dirty so foam gets broken up very fast
Hope this helps,
Rocky
Sep 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentra Shampoo tank empties too fast
You can control how much foam the unit dispenses with the dial on the tank.
Mar 17, 2009 | Kirby G5 Bagged Upright Vacuum
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
Jul 01, 2008 | Kirby G5 Bagged Upright Vacuum
Flow Indicator Not Moving, Not Dispensing Anything
The water tank and the solution tank both have red gaskets that attach to the bottoms of the tanks. Make sure they are on properly, I just had the same problem and spent hours taking apart the machine and inspecting lines to find out it was a gasket.
On my machine the red gasket for the solution got stuck in the chasis for the machine. The bissel website alludes to this, but isn't very clear.
Other posters talk about the heaters, or the lines being clogged and I immediatley inspected these areas, turns out it was a gasket that was hiding in the chasis. Both the water tank and the solution tank should have one, and make sure they don't get nestled in the chasis!
Apr 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
Jun 14, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Kirby Ultimate G Bagged Upright Vacuum Logo
179 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
