Question about Sony Cyber-Shot DSC-S50 Digital Camera
I HAVE A SONY CAMERA HAD IT FOR ABOUT 2 YRS NOW, NOW I GET THE C:13:01 FORMATTING ERROR MESSEGE. IS THERE A WAY TO FIX THIS PROBLEM WITHOUT FORMATTING THE CARD AND LOOSING MY PICTURES
    New Friend:
    Problem Solver:
  • 14 Answers
Try to reset it
Posted on Oct 25, 2010
SOURCE:
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
Sony cybershot 7.2
When memory card got unstable, camera gives format error. Format memory card by format option in camera Menu.
Jun 18, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Trying to find out what code c:13:01
The problem has nothing to do with the type or quality of the formatting. It is directly related to the disk drive malignment pandemic of Sony Mavica cameras. It seems simple enough to fix, since I fixed my own. You need to unscrew and remove all the small black screws which go around the seam of the camera body (my model was a MVC FD90) Look for little black arrows indicating the screw locations (you need a precision philips screwdriver which can be purchased at the Home Depot for $5.00 under Husky brand name). After removing all screws, try the camera now and see if it works. If it does, then reinstall only 2 screws in any of the holes that appear perfectly aligned with the camera body (hole lines up perfectly between cover holes and camera body holes). Then try again to make sure it still works. If it still doesn't work, then carefully remove camera cover with caution not to damage wire ribbon connection both halves of camera body. Then simply reinstall top with bottom of camera halves. Next,install those 2 screws previously mentioned. Camera should work fine at that point, and floppy disks will now operate when inserted without error message or other malfunctions associated with drive misalignment.
[email protected]
Nov 20, 2008 | Sony Mavica MVC-FD90 Digital Camera
Problem of blue screen error messege
you have installed the inf setup or not, install all the updated drivers of your motherboad
Oct 03, 2008 | Intel D102GGC2 Motherboard
Format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
May 31, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Error 13:01
ive had my camera for a while now..prob about 6 yrs..it will not accept any discs..it gives me a formatting error
Mar 16, 2008 | Sony Mavica MVC-FD85 Digital Camera
Why is camera saying disk error
go 2 set up hit format then yes thenok it will fix it
Mar 03, 2008 | Sony Mavica MVC-FD83 Digital Camera
Format error in Sony Cyber-Shot DSC-S650
Format the memory stick via setup menu inside the camera. Let me know if this works.
Nov 09, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Formate Error Sony Cyber Shoot DSC W50
This suggests one of 3 things. 1. Defective card, care fully clean the contacts or replace the card. 2 Dirty or defective card chamber contacts wrap apiece of clean paper around a card and carefully insert and remove several time into the chamber- thus attempting to 'polish' the contacts. take extreme care this is a very delicate area. 3. Firmware failure - there is no solution, replace the camera -unless it is under warranty Contact the Fuji technical support team at any rate.
Jun 24, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-S50 Digital Camera Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
