Question about LG Refrigerators
LG referigerotor model GL-278VES5/2010 PURCHASED a week back shows very slight ice forming in freezer. following up for 3 to 4 days for DEMO complaint no. c10A2202131. SORRY to say a disgusting service right in the ;begning. How can u assist in this matter to PROVE your service. awaiting for your quick reply . thank you, SANJEEVANI
    New Friend:
  • 51 Answers
YOUR MAY NOT WORKING PROPERLY, CONDENSER AND EVAPORATOR COIL NEED TO BE CLEAN.
YOUR DEFROST TIMER MAY NEED A LITTLE MORE TIME TO STAY ON
Posted on Oct 24, 2010
SOURCE:
Lg refrigator/freezer model LRFD25650SB purchased 2005
The defrost drain could be clogged but also Your LG unit is way overdue for replacement.
Jun 21, 2018 | LG Refrigerators
I had a Kenmore Bottom Freezer Refrigerator installed yesterday and when the installer left he told me I could put all the food back in both the fridge and freezer. Today all my food in the freezer was...
Hello Amelia;
My Name is peter. I am a retired field service refrigeration technician.
You have a brand new unit off the floor. You do not have component failure problems.
You purchased a floor model. Floor models are set in the; "Demo Mode". In this mode your unit will not cool. Taking a unit out of the demo mode depends on the model. You need to contact your place of purchase to determine what buttons you need to press to get the unit out of the demo mode.
The people who deliver the units for Sears are contractors. Physical contract laborers. Most can not speak English.
I should know, I am a former Sears Home Service refrigeration/ A&E factory Service technician; all under the same umbrella. I have heard all the complaints about Sears deliveries.
Jul 25, 2012 | Refrigerators
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
No cooling in refrig, botton freezer forming too much ice
let me know I can help you get it going again..
Sep 01, 2008 | Amana Refrigerators
Problem with GL-T 242 QM LG Fridge
Pull out the freezer and ckeck for ice build up on the back. Unplug and defrost the freezer for 3-4 hours - leave the freezer door open. There may be ice covering the vents to the fridge.
Apr 28, 2008 | LG LRBN22514ST Bottom Freezer Refrigerator
Ice forms on the bottom of the freezer
Is this a result of defrost melt liquid winding up in the bottom of the unit? Find out why it is not draining properly into the pan. A slight bit of frost is normal.
Dec 20, 2007 | GE Profile PSW26P Stainless Steel Side by...
Samsung RB215LABP Bottom Freezer Ice Maker..
refrigerator working great then the refrigerator portion went frmo 35deg to 61 freezer is at 4deg can not understand whats up and i cant get the damn thing to do ****
Oct 07, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
69 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
