Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Maytag refer model 12568 has burned electrical smell. could it be the ice maker
    New Friend:
  • 51 Answers
NO IT COULD BE A CONTACTOR ,FAN MOTOR, TIMER OR COMPRESSOR MOTOR
Posted on Oct 24, 2010
SOURCE:
I have a Maytag Ensignia model MAV4757AWW. Smelled a burning rubber smell. What might be the problem?
The most obvious best guess is an electrical problem. I'd call the Maytag guy or equivalent if it were me. . .
Jul 26, 2017 | Maytag Washing Machines
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Error code 15e samsung refrigerator sise by side bottom frezer
existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
Feb 05, 2017 | Samsung Refrigerators
My maytag fridgee has a metalic smell which has made all my food in both fridge and freezer taste bad
IF you have an automatic ice maker, the electrical connection in that is bad, you need to replace the ice maker or disconnect it and remove it.
Jul 23, 2016 | Maytag Refrigerators
I have an issue with my ice maker. Large puddle of water on the floor and a strong electrical burning smell. Have turned off the water to the ice maker and turned the switch off on the ice maker.
call in the electrician to check out the smell as that indicates wiring and insulation which could make the unit alive and unsafe
keep it switched of and unplugged until it is checked out
Jul 04, 2016 | Refrigerators
Electrical hot smell from fan area, not has quit
Hello, electrical hot smell from the fan area means you have a burnt fan which inturn affected other parts of the ice maker. That is the reason why the ice maker fails to start up when you plug it.
You can only fix it by replacing the fan and probably other affected areas by troubleshooting it.
There is nothing like reset.
Take care
Jul 12, 2010 | Continental PortableCE-IM65151 Ice Maker...
How do I decrease the water level in my Maytag Ice Maker
depends on the model of ice maker not your refer,,
if you have a white box on the end see if you can pop it oiff
if you have the adjustable model you will see a screw with a plus minus
turn to adjust.... make sure you unplug the unit first
1/4 turn is 1 oz
Oct 24, 2009 | Maytag - Model IC11B
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
