Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
How to put oster golden a5 two speed head on
I took the head off to clean and can't remember how to put it back together and I lost the instructions.
  • 2 more comments
  • Anonymous Jan 17, 2009
    I can't figure out how they go back together
  • AZ_Mensch Jan 20, 2009
    Can't figure out how to re-install the blades. The small print says to have the motor running, then snap in the blade. No success whatsoever.
  • kauffmantrus Apr 25, 2009
    I have the same problem except my clippers are Oster Model No. 78960-100
  • Anonymous May 12, 2009
  • 3 Answers
Go to: www.clipperrepair.com and look at the diagrams. It might help you. Also, I went to Oster's website and found help there with internal parts.
Posted on Oct 11, 2008
I need to know how to wire everything in the handle back together
Oster website should have all u need and i believe the diagram is able to be down loaded
Mar 15, 2013 | Oster Golden A5 2-Speed Universal Motor...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
I took the blade apart and can't figure out how to put them back together. Can you help.
the oster clippers are usually mounted with spring tab to remove blade.Should be no reassembling. If there is, it should be a couple of screws that you screw in
Oct 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Simple question: Are the Oster 76 2-speed, the Oster Crewmaster 2-speed, and the Oster A5 2-speed all the same clipper with different detachable blades?
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Oct 03, 2009 | Oster Golden A5 2-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
I need to replace the 2 speed oster A5 toggle switch and the cord. Cant figure out how to put the wires back together
I have a picture of one, can you tell me where you got the new switch, I need to replace mine.
The center lead goes under the white wire.
The two end leads both go to one of the brass connectors
The black wire goes to the other brass connector.
Note the "Tab" at the top
Mar 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Where do I put the oil in my oster a5
across the blades were they contact each other.  WD40 works fine.
Mar 07, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
920 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
