Question about Friedrich QuietMaster RS10J10 Air Conditioner
Friedrich air conditioner
The cable for the closed, exhaust, fresh air does not move the inside flap. It just stays half opened. Is it okay to use in this mode.
    Guru:
  • 1,524 Answers
Less efficent. Can you manually close it ?
Posted on May 03, 2009
Should your exhaust vent be open or close when the air condition is turn on?
It does not mater....when the exhaust is open you will vent a bit of the stale air from the house and pull in a bit off fresh air...if it is closed, it just recirculates the existing inside air...
heatman101
Jun 28, 2011 | Friedrich WallMaster WS07A10D Air...
Unit set on high cool do I have exhaust levers opened or closed
You want them exhaust levers closed. Them thangs are in my neck of the woods called Yankee air conditioning. In other words if it is cooler outside than inside you would want to open the exhaust levers to allow the fresh air in and the stale air out. If the temp outside is warmer than inside you want the exhaust to remain closed so you won't lose your cool air.
Jan 30, 2011 | Heating & Cooling
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Aug 25, 2010 | Friedrich QuietMaster RS10J10 Air...
Should the exhaust be opened or closed
Have it closed,this will allow the air in the room to be recycled,and not the hot air from outside.
May 27, 2010 | Friedrich WallMaster WS07A10D Air...
GE MODEL #AKZ10ANT window a/c. Brand new, daylight coming through top of a/c where cool air comes into room. We see the white styrofoam inside wall of a/c...all our other window a/c's are lined with dark...
They have changed thier manufacturing proccess, so it is not uncommon to see the styrofoam. As far as the light shining thru, you might want to chack and see if you have the vent setting in the open position. If it is in the open position, the square flap will be open, and depending on the model and design, you will be able to see light. The vents purpose is to let fresh air in the home, when the A/C is running, but it is not automatic, so the vent flap will stay open, till you close or turn off, the vent setting.
I hope this helps, please rate me, and contact me back with any questions.
Sincerely,
Paul Gibson
May 05, 2010 | GE AJCQ08ACB Air Conditioner
Exhaust/Fresh Air Vent
Hello there :
ok i'll explain it like this if you have the lever on exhaust it will be just circulating the air that is all ready in the room and if you have it on fresh it will be drawing the air from the outside ok hope this helpes you understand how that works please dont forget to rate my solution.
best regards
mike
(USN) RETIRED
Aug 05, 2009 | Friedrich QuietMaster RS10J10 Air...
Re: air cond. should exhaust lever be open or closed to cool off?
Im not sure what type of unit you are speaking about but in general a window airconditioner unit will have an exhaust button. This button generally opens a small door that allows a small ammount of fresh air to mix with the conditioned air from the room. When it is closed all of the air is recycled from the room. To cool a room fastest, close the outside air inlet.
Jun 21, 2009 | Heating & Cooling
My AC needs a new 220 cable
If the damage is close to the end of the cable, simply get a replacement plug end from a home repair store and put it on.
Cut the old plug off and install the new plug.
when you go to buy the cord end, take the old one with you so you get the correct configuration.
May 31, 2009 | Friedrich QuietMaster SS12L10 Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Dear cmr 1,
As you have mentioned that it look like the fan hitting something, this is possible. This kind of problem can occur while transporting the machine. Some times the fan becomes loose because of viberation. So the fan has to be realign. Regarding the tilt it is okay to have 1/4 inch tilt backwards. Since the air-conditioner is brand new it is advisable to contact the company.
regards,
ramesh22
Jun 25, 2008 | Friedrich QuietMaster Deluxe RS12L10 Air...
Friedrich QuietMaster RS10J10 Air Conditioner Logo
141 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
