Question about Samsung Televison & Video
Cannot change source on TV so it can take input from PC
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 93 Answers
You must access...setup....inputs....and specify source and name of source to apply input.
Posted on Oct 24, 2010
6ya staff
SOURCE:
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
When pressing menu on remote control I do not have a tv section listed to tune in channels
The TV channel settings Menu is usually only available when the Input is on TV. Look for a Source or Input button on the TV or the remote. Press this button and try to change to the TV source option.
Please add a comment with the make and model of the TV for additional information. (Unfortunately, many TVs don't let you change the source after pressing the Menu button and they don't always have a Source/Input button on the TV. Additionally, some replacement remotes don't even include a Source or Input button. For those with an Input button, you may need to try other codes to see if any will correctly work with the TV.)
Nov 05, 2015 | Televison & Video
How do I connect my laptop to my led tv?
Is there a HMDI output on your Laptop or a VGA output. Some TV's have a DSUB input source that allows VGA depends on your laptop it could be HDMI if so TV should have an extraz HDMI input on the back and you change the source input on the TV to the HDMI 2 or HDMI 3 source depending on where you plugged in the P.C. . If HDMI you need to buy a HDMI cable.
Sep 08, 2014 | Toshiba Satellite Computers & Internet
How to change pc mode of sharp into tv mode
Use the input selector to change back to TV. Usually the first input on the list.
Jun 26, 2014 | Sharp LC-32SB24U 32 in. LCD TV
32" samsung hdtv flat panel: switches when you don't want it from tv to av/pc or av to tv/pc.
Sometimes, TVs will switch to a new input when they sense a new signal on the new input. So if you're watching TV and someone turns on the AV device (or makes a change that alters or starts a video signal), the TV may switch over to that signal. This is a function of the TV. Some TVs allow you to disable this function, others do not. I looked in the manual and didn't notice where this could be enabled or disabled. If you want to only watch one source, make sure the other sources are turned off.
May 14, 2014 | Samsung LN32A330 32 in. LCD TV
I am trying to connect my laptop, the option for PC is not highlighted, therefore I cannot use it as an input source. Is there a way I can change the input source menu?
no you cant change the input source menu
source must be present and active for it to show in menu
make sure PC is hooked up to VGA input and make sure PC is toggled so it has the display going to TV - once this is correct you should see it as an input option
write back if you need more help and give m,e more details like what type of PC you are hooking up as well as what input and wiring you are trying
good luck!!!
Mar 29, 2011 | Samsung LN40A550 LCD TV
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
How do I get back to the right input? Model TXE2546 25" TV
To change the input source for your TV, you can use your remote to change the video source by following these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 17, 2009 | Samsung TXE2546 25" TV
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 28, 2009 | Philips 19PR19 19" TV
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Open Questions:
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
