Question about Toshiba Tecra 9100 Laptops
When I turn power on aget the message PXE-E61 Media Test Failure, check cable followed by PXE-M0F Exiting Intel PXE ROM and Insert system disk in drive. Cannot get out of this loop
  • Ian Thomson Oct 24, 2010
    How do I remove the other devices from the boot sequence and disable boot from LAN?
  • Toshiba Master
  • 32,281 Answers
Normal 0 The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. If this does not work then reboot and go to the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Next - to determine if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and you cannot open the various folders and files, this confirms the hard drive is faulty.
The hard drive needs to be replaces in the laptop and Windows installed and the laptop's device drivers and your programs etc to get a functioning laptop again.
Posted on Oct 24, 2010
  • Chris Hingee
    Chris Hingee Nov 01, 2010
    You can disable the LAN from the boot up by going into the BIOS configuration by disabling the LAN or remove it from the boot up sequence.
    You can also disable any devices in Device Manager. Click on Control Panel - System - Hardware - Device Manager , Then go to the device and right click on that device and click Disable.
    President:
  • 2,185 Answers
This means that your computer could not boot to your hard drive and is trying to boot to another device. Go to your BIOS settings and on the boot options, make sure that your hard disk is on the top of the list. Also, remove the "other devices" out of the boot sequence.
Further, check if boot from LAN is enabled (this should be disabled). PXE will enable you to boot from a network drive or server, which you dont need, I suppose.
If the above suggestions was already done and still could not boot to windows, then it failed to read your harddisk, thus, could not find the OS of your computer. You needed a new hard disk if this is the case.
Please let me know how this assistance help you. Thank you for using FixYa.
  • virtualhost
    virtualhost Oct 24, 2010
    Upon starting your computer continuously press F2 or the Del button to go to your BIOS settings. Once in there, go to Boot menu and make sure your harddisk is on priority among the list. Try to see if "Other Devices" is listed there. Then go to the other menu aside from Boot, and Boot from Lan option, if it is enabled, then highlight it to select and then press spacebar to make it disabled.
SOURCE:
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Boot
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Geoff
Aug 28, 2008 | Tablets & eReaders
PXE MOF problem
First, try and access your cmos setup. Look to see if your harddrive shows up.
Apr 06, 2008 | Toshiba TE2100 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Oct 10, 2006 | Compaq Evo Notebook N200 Notebook
Open Questions:
Amazon Prime rEfUnD pHoNe #{+1-85O-8I2-4OO9 caNaDa how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number.AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
See all Toshiba Tecra 9100 Laptops Questions
Toshiba Tecra 9100 Laptops Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
