Question about Sony CDP-CX450 400-Disc CD Changer
Need belts that turn table and load disc - Sony CDP-CX450 400-Disc CD Changer
    New Friend:
  • 120 Answers
Go to Emcompass parts or MCM Electronics!
Posted on Oct 24, 2010
SOURCE:
CDP-CX400, turns slowly, displays 'Loading Error'. Disc DOES load but does NOT SPIN. Looks like the drive belts might be slipping. Do the drive belts spin the CD as well as turning the table?
It could be that the lens is dirty so can't see the disc. Generally a motor turns the CD direct. Though things like switches or damage to the mechanism can affect the motor's operation.
Drive belts might move the carriage up and down. You can tell if a belt is worn by looking at it. Plus there might be black dirt on the surfaces it comes into contact with.
But try cleaning the lens first, you can also look to see if it has scratches on the lens. That will cause it never to read another CD again.
Apr 17, 2018 | The Audio Players & Recorders
It's displaying "TRAY ERROR", why can't I open trays. Thanks
Maybe the time to load the disc is not made fast enough , bad timing because of a bad drive belt that will load the tray but there is also a microswitch that will be activate somewhere on the tray if its closed the laser if disc was loaded that will activate the focussing of the laser to read table of contents . a little suggestion comes here .
How to Fix stuck CD Tray
Mar 13, 2016 | Televison & Video
Disc table just keeps moving back and forth and never stops to play cd? What is the problem?
If you have a "jukebox" player, worn drive belts can prevent the carrier from indexing properly to locate and load a disc.
Jan 03, 2015 | Audio Players & Recorders
Cd player indicates Table Error
The belt in the back of the player under the hood is either broke or has came off the rollers. You will need to take the top off and replace the belt a rubber band will work as a temporary fix till you can order a new belt.
May 28, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
Table Error
After replacing belts, turntable moves to position disc 1 in front of loader then swings back and forth 10 times and posts "TABLE ERROR" again. If I apply slight clockwise pressure to table, then disc loads OK. On unload, table rotates to position disc 1 in front, door opens, then table oscillates another 10 times and posts "TABLE ERROR" again. Any hints?
Feb 03, 2014 | Sony CDP-CX335 300-Disc CD Changer
Will not eject
The problem here is most likely a slipping load belt.
What is happening is that when a disc is loaded, the final stage of the loading sequence causes a magnetic "clamper" to clamp the disk to the CD table. The CD table is the part attached to a motor that spins the disk, If the belt has become slippery ( due to age and heat), there won't be enough grip to break the clamper grip and the disk won't be ejected. To fix this, you must dis-assemble the unit and remove the disc by hand. Then you replace the belt and you are all set. These wave radios are tricky to open if you have not done one before and because of that, this is really not a DIY repair. The belt costs around $5
Hope this helps,
Dan
Mar 18, 2010 | Bose & Wave& Music System
Sony CDP-CX450 400-Disc CD Changer Logo
220 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
