Question about Arris SURFboard® SB5101 Cable Modem
So every now and then i get spikes,and im pretty sure that they are because of the modem.When im playing something,no mather what like every 5-10 minutes ill get a massive 10-15 spike.Its like the internet stops for that time and its really annoying.I tryed using a friends modem which is not motorola and i don't have that problem(my friedns modem is like 300 usd).So i was wondering if theres a way to fix it without having to buy a new one.I tryed restaring it,messing around with the connection settings,changing the cables but its still the same. (sorry for the bad English,i was born in Bulgaria :P)
    Habit-Forming:
  • 188 Answers
Imply configure it properly.....or may be this modem does not support your box....just chk its user manual...
Posted on Aug 18, 2017
SOURCE:
  • 39 Answers
SOURCE: Re-starting a ARRIS modem after a loss of power
You can try doing a "Hard reset" on the modem but it looks like you've tried most combinations. To do the hard reset: - unplug the coax cable from the back of the modem - Push and hold the "reset" button in for 15 seconds - Allow the modem 30 seconds to reinitialize and then plug the coax cable back in. Within 10minutes you should have activity back. If not, the modem needs to be replaced. I know you may have tried something similar to this but I'm hoping this may help.
Posted on Aug 13, 2007
  • 142 Answers
SOURCE: DISCONNECT EVERYTIME
Modems firmware needs to be updated
or
Electrical interference is causing all the trouble
Make sure there is no interfernce in the surrounding
Posted on Jun 07, 2008
ohms
  • 1879 Answers
SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
  • 115 Answers
SOURCE: Online problem with motorola SBG900
hardwire the modem with the acer computer and shut both the modem and the computer down..then turn on the modem ..wait for a minute and then turn on the computer..just check whether the status still says local or not.....remember this is the first step..if it doesnt work,,keep me infmd,,i will be back with u
Posted on May 14, 2009
leecom72
  • 4806 Answers
SOURCE: Dear forum-freinds,
If you say the lights are going out on the modem when it boots you off the network then the problem is your modem and not your internet connection, if the modem is new take it back and have them swap it for another one.
Regards.
Posted on Jul 01, 2009
Fisher PC-6520
I am pretty sure you can hook up a PS2 but im not sure about the wii console you probably can though.
Apr 10, 2013 | Computers & Internet
What's your problem? hiteker remote code for directv
Use codes for Curtis Mather. 10060 was the directtv code for my TV; pretty sure the Curtis M codes will work with other Hiteker devides.
Jul 15, 2012 | Televison & Video
Im playing call of duty and cannot get onto any online games. I have an internet connection and im at the rank of lance cpl 2nd class but I cant play on any games?
Make sure that you NAT TYPE isn't moderate or strict if so factory reset the modem/router and if that doesn't do it, go into your modem/router via PC and set your PS3 as a DMZ host. NOT: Setting you PS3 system as a DMZ host puts your console outside the firewall.
Feb 11, 2011 | Sony Playstation 3 (PS3) Console
Dell Latitude D830 instant off whenever loud sound played
Either that or the battery is near the end of its life and when a big spike in current is needed it fails so the voltage drops and the processor chokes, instantly shutting it down.
Jun 01, 2010 | Dell Latitude D830 Notebook
I have a dial up connection hooked through a surge protector.After a lightning storm I could no longer dial up,the problem is in the computer,was wondering if the modem is bad.
Sounds as though the modem has been spiked by the lightening flash, even surge protectors can fail to protect in heavy weather. By another modem ..... they are pretty cheap nowadays.
Jan 01, 2010 | Computers & Internet
Im having Lag Spikes on xbox 360.
Call your ISP and have them do a line test.
from your PC, go to www.speedtest.net and perform a speed and latency test.
Give this info to your ISP.
Jun 23, 2009 | 2wire (1000-000057-000) Modem
My alpine car cd player wont stay on....
There is a Title button (above the volume knob). Push it and hold it for 2 or 3 seconds. It was either that, or push and hold the 'Function" button on the glide bar... pretty sure it was the title button though. It will come back on.
Apr 07, 2009 | Alpine CDA-9855 CD, WMA, MP3 Player
Thnks
Hello!
don't worry, we will figure it out.. i'm pretty sure that you surely did the right thing. its probably the modem itself that is not cooperating here. if you dont see any dsl light on the modem that is because the modem is not yet setup.
nwy, since you already try setting it up using the installation cd, let's try to do check it manually instead
check your cable connection:
step 1: Power supply connected
Step 2: Phone cable to the DSL port of the modem to the DSL outlet
Step 3: Ethernet cable from the ethernet port of the modem to your pc
device configuration:
Step 1:open browser and type 192.168.1.254
Step 2: create your own password
Step 3: username admin and the password you created
Step 4: type your ISP user ID and password
Step 5: it should give your the confirmation that you are now connected
May 08, 2008 | Computers & Internet
Code changes
im pretty sure the code is 0000 just keep typing it in, my friend got it unlocked for me but im pretty sure its just 4 zero`s
Apr 28, 2008 | LG XBR446 DVD Recorder/VCR
Speakers blew out
im pretty sure that there is no possible way to fix those speakers but new ones will work just fine. (ive had this problem but different circumstances) Hope i helped!
Dec 22, 2006 | Dell A215 Computer Speakers
Arris SURFboard® SB5101 Cable Modem Logo
81 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
