My Kenmore Progressive Upright Vacuum with Inteli-Clean System, Slate Blue02035923000 Mfr. model# 35923 is very difficult to push on carpet in all but the highest height setting, even on very low-pile carpet. I've had the vacuum for 2 years and it has progressively become harder to push on carpet. Am I missing some simple maintenance? Help!:)
SOURCE: Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
SOURCE: i need to take apart my Kenmore Progressive
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Inteli sensor not work, with in 5 second, turned to green,,,, I guess sensor tube is blocked, but i do not know how to clean the sensor....
Had the same problem with a Kenmore upright.It was very hard to push. The rubber rings on the wheels would get off track. I ended up taking the rubber rings off the wheels. Worked fine after that.
