Question about NEC ND-3540A DVD RW Dual Layer Burner
Error code 39 missing driver or corrupted - NEC ND-3540A DVD RW Dual Layer Burner
  • 192 Answers
Hi chillango1,
It is required to edit the registry files to fix this issue. Editing the registry incorrectly may cause series software issues in the Computer. Hence, please backup the registry before proceeding for editing.
To backup the registry, please open the run window and type regedit. Then in the Registry Editor window, please click File and click Export. Please select a location to save the file.
After saving the file, please proceed to edit registry.
Please click the "+" symbol next to HKEY_LOCAL_MACHINE, System, CurrentControlSet, Control, Class and click on the {4D36E965-E325-11CE-BFC1-08002BE10318}.
Then you can view the UpperFilters and LowerFilters values on the right pane of the Registry Editor window. Please right click on UpperFilters and select Delete, then select LowerFilters and select Delete.
After that close the Registry Editor window and restart the Computer.
This should fix it.
Good Luck
Please post back if you require further assistance.
Thanks for using FixYa.
Posted on Oct 24, 2010
2 Suggested Answers
SOURCE:
  • 1257 Answers
SOURCE: Windows cannot load the device
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Could not load the driver for this device. Perhaps the driver is corrupted or missing. (Code 39)
hi code 39 is a error code for a missing driver usually cd/dvd rom. go to my computer and right click /click properties /check for yellow exclamation marks against your cd/dvd rom /click/click update drivers.close program see if problem is fixed if not/
Read more: How to Fix Code 39 Driver Error | eHow.com http://www.ehow.com/how_5344400_fix-code-driver-error.html#ixzz0xzIAh2xi
follow this link .hope this helps.
Aug 29, 2010 | Computers & Internet
Canon CanoScan LiDE 25 Flatbed code 39
Did the message say:
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Download the Delete driver application from Canon's website and run it. After deleting this and rebooting, try installing again.
May 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Hitachi-lg cd-rw gce-8487b device driver corrupted or missing error code 39
You may find your driver here: http://us.lgservice.com/ or here: http://www.kauaikeepsakes.com/computerguy/
Good luck
Mar 22, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Open Questions:
&^%#`[email protected]# AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 21, 2019 | Amazon Computers & Internet
See all NEC ND-3540A DVD RW Dual Layer Burner Questions
NEC ND-3540A DVD RW Dual Layer Burner Logo
154 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
