Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
My Active smart f/p refidgerator lights keep beeping after I defrosted and cleaned worked for 24 hrs and then stasrted beeping again please can you help freezer compart light flashing
    New Friend:
  • 51 Answers
UNPLUG THE POWER SUPPLY FOR ABOUT 30 MINUT AND PLUG IT BACK
Posted on Oct 24, 2010
SOURCE:
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Nov 26, 2011 | Refrigerators
I accidenly spamed someone and need to know how to fix it on facebook.
Not to worry as it will report facebook administrators and after 24 to 48 hrs there account will be active again. Usually if you spam their acount will not be blocked only if multiple users report as spam it will blocked for 24 to 48 hrs and later will be active again. If it is repeatly spamed by multiple users then it will be blocked permanently.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution as it will be appreciated.
Thank you
Gowtam R
Jun 24, 2011 | Facebook Computers & Internet
Hi My Fisher & Paykel Model: E522B starts beeping for no reason at random times. When I press the cooler/warmer settings it stops but will start beeping again randomly at a later time. Please...
Hi - I believe the problem is the power module located on the rear of the machine. I have not done work on F&Paykels for a long time.
Whats happenning is the controls is picking up an error with the input power supply, the modules perhaps got an intyermittent issue.
Try this turn your fridge off & back on again - the E522B will start to beep indicating the lose of power which is exactly whats happening to the unit at the moment, to eliminate the beeps you reset with the temp button on the inside.
Jun 14, 2011 | Fisher and Paykel Active Smart E522B...
KU15RA50GB - iQ100 Built-in fridge stopped working the back of the fridge defrosted, i moved the unit where the light and temp dial are situated and the fridge started to work again for aprox 24 hrs then...
if the frig keeps frosting then it must have a defrost problem as the nofrost ref do not have frost . i thim=nk that moving the frig is only looking like it changes things but the problem still is in the no frost system .. mm
Sep 01, 2010 | Siemens Refrigerators
Hi I have the same fridge freezer and it is blowing house fuse/ i have defrosted and clean etc let stand over night, started fine this morning then blew fuse agian this afternoon ? any ideas? many thanks
likely is a shorted to earth defrost element, which is engaged every 12 hrs for defrosting the evaporator coil, this is one of only two components that is mains voltage and is a common fault.... hope this will help
Jun 08, 2010 | Fisher and Paykel Active Smart E522B...
Ice on refrigerator motor?
The fan in question is the evaporator fan motor and is hitting the ice. The problem is the freezer is not going into defrost due to a faulty defrost thermostat , heater, or timer. You have to call them back out free of charge on there 2nd time out and have them repair it right.
Sincerely,
Shastalaker7
Dec 30, 2009 | Fisher and Paykel Active Smart E522B...
Refridgerator does not keep cool.Replaced the defrost thermostat and keeps doing the same thing. I have to unplug and thaw for 24 hrs and fridge works again for 2- 3 weeks and i have to repeat the thawing.
More often than not , when a defrost problem occurs , the defrost heater is the problem . With your G E , the heater is in a glass tube , below the coils . If you replace this , then the defrost timer would be the only part of the defrost system left .
Sep 10, 2009 | GE Refrigerators
My GE 21.7 cf no-ffrost side by side keeps running, leaks water to the floor and warms up. Age unknown. What might be wrong?
the drain must be plugged . defrost the freezer (leave unpluged with door open for 24 to 48 hrs or untill it stops leaking water...
clean and clear drain plug back in and it will work like a charm...
please let me know
Jul 21, 2008 | Refrigerators
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
537 people viewed this question
Top Fisher and Paykel Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Mark Davis
Level 1 Expert
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
