Question about Belkin F5D8631-4 Router (F5D8631au4A)
Client ip filters not working - Belkin F5D8631-4 Router (F5D8631au4A)
    Habit-Forming:
  • 144 Answers
Login into the router .
go into previllage mode and check the ACL,
cnfigure the Acl as per ur requirements
Posted on Oct 25, 2010
  • ron_i Oct 26, 2010
    Where will I find the previllage mode Sir?
SOURCE:
Issue with time synchronizing(NTP) on layer 2 switch
I know this is probably not going to help you out but you did try going to Alcatel-Lucents web page and search through there or calling them at 800 995-2696? Good Luck! Sorry I couldn't be of some help
Mar 04, 2014 | Alcatel OmniSwitch 6850 (OS6850-48)
Port forwarding
Try to put your IP manually as defined for your client.
Go on to your Lan connection or wifi conection insert static ip there too and check weather its pining with your router or not. if pining with the router ip than it will work.
I hope, it works.
Thanks,
Feel free to get instant router help at http://www.vtechsquad.com/wireless-router-support/ to fix any issues with your any other router.
Jan 22, 2013 | SIIG CN-WR0512-S1 Wireless-N MIMO Router
Handy cafe clients could not connect to server. i manually configured the server ip and they are now visible to the server. however ither server cannot control the clients
I am sick of my handycafe server keeps changing its ip addres.....i have to reconfigure from each client every day.....how can i just change my handy cafe server ip address......?
May 22, 2012 | Computers & Internet
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
We have a DHCP problem with our thin client HP T5540, the network interface can't get an ip address fom the DHCP server for 30 seconds so it can't connect to citrix xen serverver for virtualization...
First of all check the configuration of the unit if it's AUTOMATIC IP/DHCP, if all OK you can test by configuring a static IP (use an unused IP in the server's DHCP table) than check the connectivity (ping something), if that works you have a server rule/DHCP or DNS problem
if it's still not working check the cabeling and connectors for connectivity (with a good cable tester) or an other (working) computer.
Oct 22, 2010 | HP t5540 VIA Eden 1GHz Thin Client...
How to configure the two wifi router
Are you trying to cascade two wireless routers? If yes, here's how:
1. First make sure that the first router (will serve as the server router) should be working. And then get the IP address of the server router.
2. Connect a CAT5 cable from the WAN port of the server router and the other end of the CAT5 cable should be connected to any of the LAN ports of the client router (which is the second router).
3. Then connect a computer directly to the client router and access its WEB UI.
4. Disable the DHCP server capability of the client router and set a static IP on the client router and make sure that it has the same IP range as the server router so that they would communicate.
5. After making sure that the two routers are on the same IP range, connect a computer to the server router and then ping the IP of the client router. Once you can ping it, then it should work.
If you're having a trouble with the setup or should you wish to have more information about the router, then refer to the router's user manual for necessary information.
Good luck and have a great day!
Feb 09, 2010 | Linksys Computers & Internet
Networking problem
From client pc
1.) click start
2.)click run
3.)in the box that opens, type cmd
4.)click ok button
A black box will appear
5.) type ipconfig
6.)press the enter key
Some lines of text will appear. One of these lines says IP Address please take note of the numbers to left of this. This is your Clients IP address
Now, you said your server IP address is 192.168.1.2 and lets say from the instructions I just gave you that you find your client IP address is 192.168.2.5. If your client pc does not have an IP address that begins with 192.168.1 it will not see your server. Also, If your client pc in question has an IP address the same as another one of your client pc's it will not see a server.
I suggest the following.
Change the IP address on your client pc following these steps
From the desktop of the client pc
1.)click start
2.)open control panel
3.)double click Network Connections
4.)right click Local Area Connection (it is possible to have more than one)
5.)left click properties
6.)a window will open, in the middle of this window is box you can scroll down in, scroll down and find TCP/IP
7.) left click on TCP/IP to highlight it
8.)once highlighted click the properties buttton just below the scroll box.
9.)another window will open
10.)click the dot next to Use the following IP Address
11.) enter the following
IP Address = 192.168.1.??? (replace question marks with a number of your choosing. Just dont go above 254 and don't use a number that you are using on your other pc's)
Subnet Mask = 255.255.255.0
Gateway = 192.168.1.2
12.) click ok
13.) click ok on any other open windows and reboot PC. then test connectivity.
PLEASE NOTE: There are alot of things that can change what you need to enter for the Gateway, Subnet Mask and IP address. Generally with simple networking it is what i have described above but if you have a Cable/DSL router for internet or wireless router then the numbers you must put in these fields changes. The directions I gave you above is assuming that you just want to get your pc talking to your server. It does not take into account any routers or advanced networking equipment. If you do have a router I will need more info and a somewhat different set of directions will apply.
Feb 19, 2009 | Microsoft Windows XP Professional
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Open Questions:
Belkin F5D8631-4 Router (F5D8631au4A) Logo
162 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
