Question about SanDisk 2GB microSD Memory Card
When i open my digital camera with the card inserted (4GB micro sd HC) then, it is displayed as WRITE PROTECT and cannot proceed further. Please provide solutions.pleaseee
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Feb 11, 2011
SOURCE:
I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put the chp in it reads memory full. The chips work in anything else but wont work in the camcorder. How do I fix this?
Whats the size of your SD Micro chip? Is it 4GB or larger?
You probably bought a SD-HC chip (wich includes 4GB and larger chips). Any SD card that is bigger than 2GB is in this HC-format and will only work if the device supports it.
As you can see here in the description, your device does infact only support SD cards up to 2GB. http://www.amazon.com/Jazz-DV151-Digital-Video-Camera/dp/B001F7MXJS
I guess you will need to use smaller ones in order to make them work with your camcorder.
Best regards from Germany :)
May 02, 2011 | Video Cameras
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk 2GB microSD Memory Card Logo
52 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
