Question about Compaq (176763001) 120-Watt Power Supply
Power supply dead due to low voltage - Compaq (176763001) 120-Watt Power Supply
  • Compaq Master
  • 32,281 Answers
You do not have any choice but to buy a new power supply.
Posted on Oct 24, 2010
SOURCE:
My Samsung HdTv will not come back on. Only a small red light next to the power button is blinking. First it was blinking six times then five now six again. Model TXR3079 or 8WHKXXAA. Samsung hdtv...
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Aug 27, 2011 | Samsung Televison & Video
Hi I have a 32LG3000 TV and it is showing a flashing red light and will not turn on. I have pulled the plug out etc but no luck. Can you advice? Marion
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise, power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care to solve the problem....
Aug 08, 2011 | LG 26LX2D 26 in. LCD HDTV
Sony wega rear projection ,picture goes out for 30 seconds comes back on
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise,Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
This will help to solve the problem, and do take care in solving the problem, because it contain high voltages...
Aug 04, 2011 | Sony KDF-E55A20 55 in. LCD Television
I WONT TURN ON
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out transistor and zenerdiode, if otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope that this will help in solving the problem, also do take care in handling the fault, because it contains high voltages...
Jun 16, 2011 | Polaroid Televison & Video
Won't power on
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if other otherwise Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Take care in solving the problem,because it contain high voltage...
Jun 14, 2011 | Televison & Video
Had a low voltage problem in the home. Main powerline at pole had one line broken almost all the way through, lights were dim, clothes dryer would not start, micro wouldn't heat, other stuff. After we got...
I would recommend checking the power supply first but it is possible the board may have gone as well.
Usually random shut offs or restarts are power related
Jun 24, 2010 | Computers & Internet
Need to know "no bus" indicator light on instrument panel....
"No Bus" means the data cable going to the (PCM) computer is unplugged, or the PCM has failed and not able to read the information it is being given.
Sometimes just jiggling the PCM causes the ODO "NO BUS" to come on.
Sometimes a bad crank or cam sensor can cause this as well.
Here is the OFFICIAL checklist for the "NO BUS" condition....
Vehicle: 1998 - 1999 Dodge Durango 3.9L
2000 - 2001 Dodge Durango 4.7L
1998 - 2000 Dodge Durango 5.2L
1998 - 2001 Dodge Durango 5.9L
Symptom: Engine will not start. Gauges are inoperative. No BUS message displayed on odometer.
System: Body/Chassis Electrical, Emissions/PCM/Fuel, Engine Electrical
Codes: N/A
Problem 1 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Crankshaft Position (CKP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) sensor. If 5v is not present, unplug the Crankshaft Position (CKP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CKP sensor.
Problem 2 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Camshaft Position (CMP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the Camshaft Position (CMP) Sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the CMP sensor.
Problem 3 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Manifold Absolute Pressure (MAP) Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5v power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the MAP sensor. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the MAP sensor.
Problem 4 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Throttle Position Sensor (TPS).
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire (5 volt power supply) at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the TPS. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, replace the TPS.
Problem 5 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted wire.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the throttle position sensor (TPS) or manifold absolute pressure (MAP) sensor. If 5v is not present, unplug all sensors that are connected to the 5v power supply and disconnect the PCM. Check if either 5v power supply circuit is shorted to ground using a DVOM. If the circuit is found to be shorted to ground, repair the wire and the cause of the short.
Problem 6 of 6: The 5v power supply from the Powertrain Control Module (PCM) is shorted due to a shorted Governor Pressure Sensor.
Test & Fix: If the 5v power supply circuit is shorted to ground, the CCD bus is unable to transmit messages and the Powertrain Control Module (PCM) appears to be "dead". The PCM is not damaged when the 5v power supply gets shorted to ground, but does need to be reset by turning the key off for 10 second after the short is removed. Using a DVOM or labscope, measure the voltage on the 5v reference wire at the Throttle Position Sensor (TPS) or Manifold Absolute Pressure (MAP) Sensor. If 5v is not present, unplug the large round connector on the driver's side of the transmission. Turn the key off for 10 seconds. Turn the key on and measure the voltage on the 5v power supply circuit. If the voltage is now 5v, remove the transmission pan and check for shorted wiring inside the transmission. If the wiring is OK, replace the Governor Pressure Sensor.
Many times the PCM simply overheats - and changing it will stop the problem.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | 1999 Dodge Durango
SONY TV KV2185AS POWER SUPPLY DEAD, OPENED COVER IC601,C606 & C607 HAVE PHYSICAL DAMAGE. SHOULD I CHECK ANYTHING ELSE BEFORE REPLACING THESE COMPONENTS. I HAVE ELECTRONICS KNOWLEDGE AND AM HANDY WITH A...
Would not recommend repairing this unit as Sonys have no over current protection in the low voltage power supply, which means the low voltage power supply failure you describe is not the root fault. Rather the root fault is highly likely to be bad connections on the main board, leaky diodes near the high voltage power supply, a bad fly back transformer (which Sonys are famous for), or an intermittently arching picture tube, which is also a common Sony problem.
The horizontal output transistor may be shorted as well and if it is, it is also not the root fault. If somehow you manage to repair the circuits that you mentioned, it is highly unlikely that the unit will last very long. In summary, if your unit was a larger, more expensive model it would be worth pursuing all of the root faults causing the collateral damage in the low voltage power supply.
Apr 28, 2009 | Televison & Video
2000 Ram 1500 4x4 "no bus"
All the modules are connected together to communicate with each other via the PCI bus. It is possible that one of the modules is pulling the bus down. If the vehicle won't start it could be any one of the modules. It will be a process of elimination to find the faulty one by disconnecting them one at a time.
Apr 22, 2009 | 1998 Dodge Ram 1500 4WD
Tv
Check the transistors around the power supply, most likely there is one that is that is shoted out.
Sep 10, 2007 | Panasonic CT-27G14 27" TV
Compaq (176763001) 120-Watt Power Supply Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
