Question about Averatec 3200 Notebook
1 usb port cant detect a flash drive but can detect other usb devices
  • 409 Answers
I'd say its the flash drive thats faulty .Try it in another computer to see if its recognized.If not the flash drive itself is bad.That port recognizing other devices says it functioning as intended.
Posted on Oct 24, 2010
6ya staff
SOURCE:
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
When i plug my 4g cruzer micro usb memory stick nothing happens the cpmuter dosnt read that it is plugged in
Try a different USB device on each of the USB ports on your computer.
Hopefully, all your USB ports are working correctly.
Try a different USB port on your computer.
Hopefully, the SanDisk will be detected on one of the ports.
Try a USB port on a different computer.
If the SanDisk still is not detected, then spend $10 to buy a new 4GB flash-drive.
May 22, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My 8G usb can't be detected by my computer, my flash drive was brought 3 months ago and only half of it was used
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Apr 11, 2011 | Office Equipment & Supplies
Computer isn't noticing USB is there. USB is not lighting up orange.
Try another USB port, to see if you have a "dead" USB port.
Try the flash-drive in a different computer, to see if the flash-drive is "dead".
Try a different USB device in the USB port on your computer, to see if _any_ device in that port can be detected.
Jan 27, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
My HP compaq d530 doesn't detect any USB drive. I'm trying to upload a sound driver onto it and I don't have a CD. I put the driver onto a USB drive but the computer doesn't detect the drive. I just...
So we have two problems one your sound is not working and two your usb drive is not detecting any connected devices, correct?
Starting with the sound simply use a friends computer to burn the audio driver onto a cd. Next install the driver on your machine.
Problem two the usb. Remove the flash drive and try plugging in any other usb device such as a printer or camer or cell phone and see if windows says found new hardware. You don't need to install it this will simply tell you if your usb port is functioning or has a problem. if you do get a found new hardware message then your usb port is functioning and may only have a problem seeing your flash drive. Try uninstalling the usb port in System Properties. Right click on My Computer then left click on Properties. Now click on the Hardware tab. Now click on Device manager. Now go to the bottom where the usb devices are and uninstall all usb devices and when your done restart the machine. See if you can use your flash drive now. Other wise check your bios settings for the usb devices to see that they are infact set correctly and if you cant do this take it to your local pc repair shop and they can do this for you.
Hope this helps.
Sep 24, 2009 | HP Compaq d530 CMT PC Desktop
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
8gb Emprex flash drive has died. Windows does not see it and the light does not flash
check if the usb port is enabled under device manager. right click my computer then click manage. go to device manager and make sure that there are no red X or yellow ! on any of the devices. If everything is good, try your flash drive on another usb port or another computer. if other computers cannot detect your flash drive, it's broken.
Nov 10, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
54 people viewed this question
Top Averatec Computers & Internet Experts
Ekse
Evan Benson
Evan Benson
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
