Question about Dell Inspiron 530 Desktop Computer
My Dell Inspiron 530 Desktop computer using windows Vista, will not start up, when I try it just makes 4 beeps and repeats. The fans are running and everything, but the monitor is blank. I have not recently done anything to this computer, and it was fine hours before.
    Sergeant:
    Champion:
  • 390 Answers
Goto this web address for dell
http://supportapj.dell.com/support/edocs/systems/inspd530/en/OM/HTML/trouble.htm#wp1085300
just copy and paste to your browser
it show the beep codes and it says its your memory moduals.
i would try to pull them out,keeping them in order,clean the contacts with a non fuzzy cloth with some 70 percent or better rubbing alcohol let dry and then reseat them.
if you have more than 1 modual and it doesnt work when u put them back in then try useing 1 at a time to see which 1 is bad.
Posted on Oct 24, 2010
    Guru:
  • 846 Answers
Unplug your RAM, clean it a bit and plug it in properly...also remove any dust inside the CPU......and check that all the wires are connected properly........
SOURCE:
  • 24 Answers
SOURCE: Dell Inspiron 530 + Vista music sound popping crackle
check you speakers or try reinstalling the sound drives
Posted on Dec 20, 2008
  • 916 Answers
SOURCE: Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Posted on Jun 25, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
  • 3940 Answers
SOURCE: Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Posted on Mar 09, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Inspiron 530 mobo dead, beeps 2x, no video
The two beep code means no memory was detected. This might mean bad memory, memory that's loose in its socket, or a system board problem.
Make sure all the memory is firmly seated and latched into the sockets.
If you have only one RAM module installed, try substituting a known good part of the same type to see if the trouble clears up. If the memory still isn't detected you'll need a new motherboard.
If you have more than one RAM module, try them one at a time to see if you can isolate which is causing the trouble. (Testing the motherboard with known good memory is always a good thing to try. I have seen computers where all three RAM sticks were bad at one time, so I wrongly thought the motherboard was at fault. I always keep some good memory around for testing now.)
Good luck, and thanks for using Fixya!
Posted on Mar 27, 2010
When i start my dell inspiron 530 desktop....
according to dell's documentation, 2 short beeps means a memory problem. try the suggested remedy in their site.
don't forget to rate me if I was able to help out. :)
Jan 10, 2012 | Dell Inspiron 530 Desktop Computer
Dell inspiron 530s.when powered up cpu.fan runs very fast,computer gives 1 beep then powers off.It sometimes restarts itself only for the same thing to occur.
Good Morning--The 1 beep with the Dell Inspiron 530 is due to a bios check sum failure and or possible motherboard failure. The best resolution is to contact Dell and to see what they say. If you have any other questions--feel free to contact us at [email protected]
Mar 30, 2011 | Dell Inspiron 530 Desktop Computer
I have a Inspiron 530... The monitor reads "NO
Hello
You may try another graphic card, it is quite possible the card may not compatible with board, also push the RAM stick to place them properly may the RAM gone dislocated.
Hope it helps
Dec 30, 2010 | Dell desktop and monitor- Inspiron 530...
The mother board is burn up and the fan do not come on in my dell 530s computer, can i transfer my file to my new dell Inspiron 570mt computer
Remove the harddisk from the old PC and connect it to the new pc's motherboard as secondary harddisk then start transferring files to the primary harddisk of the new PC.
Sep 03, 2010 | Dell Inspiron 530 -Intel® Pentium®...
My Dell Inspiron 530, works fine once its powered up, but it take three attempts for the computer to boot on. I have taken the following steps. Checked that all fans are operational, they are. I have...
OK, here is what dell says:
BIOS checksum failure. Possible motherboard failure.
Try re-seating your memory modules and see if the beep code disappears
Also, Try using the Dell Diagnostics which is located on a hidden diagnostic utility partition on your hard drive or on the Drivers and Utilities Cd that came with your computer.
  1. Ensure that the computer is connected to an electrical outlet that is known to be working properly.
  2. Turn on (or restart) your computer.
  3. When the DELL™ logo appears, press <F12> immediately. Select Boot to Utility Partition from the boot menu and press <Enter>.
Press any key to start the Dell Diagnostics from the diagnostics utility partition on your hard drive.
Dec 29, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
189 people viewed this question
Ekse
Clive
Clive
