Question about HP Pavilion dv9310us Notebook
HP DV9310US 17" laptop won't boot, no light on display, disk access light flashes once and that's it. Any ideas?
  • 2,567 Answers
Please follow the diagnosis outlined in this article to check whether the backlight lamp or the inverter board are the root cause of the problem or not:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
If you connect the external monitor & nothing is displayed on it, then this means that both the backlight lamp & the inverter board are fine. The main indicators in these cases are the sound, and the hard drive LED on the laptop case. If the laptop sounds just like it always does for a minute or two after being turned on, it means it's going ahead and booting the operating system, but the video processor or part of the motherboard circuit for video output has failed. If the laptop just sits there and beeps when you turn it on, or if you hear the fan but not the hard drive chuckling with its active LED flashing away, it means the laptop isn't getting as far as trying to boot the operating system. While this could be due to any number of hardware problems, the most common and easiest to
troubleshoot or repair is RAM failure. If your laptop has two RAM modules installed, try booting with just one and then the other in the primary slot. If your laptop only has one RAM module, you might consider buying one online from a site with a good memory selector, like Crucial.com.
Posted on Oct 24, 2010
Testimonial: "Very sound advice but unfortunately it did not fix my problem."
  • lelandford Oct 24, 2010
    Tried external display and memory module swapping. Nothing worked. Any more ideas?
  • Mohamed Omran Oct 24, 2010
    This would mean that we have a bad motherboard here. We need to find a replacement motherboard, fully disassemble the laptop, swap the motherboards,
SOURCE:
HP Pavilion dv9310us laptop Power Lights
Plz define briefly. Its ram or chip problem
Mar 16, 2014 | HP Pavilion dv9310us Notebook
I have a dv9310us. I upgraded to 7 Ultimate, hunted down all of the drivers...it was in prime condition. I then flashed the BIOS with the Vista 32-bit found on the hp site. Now when I push the power...
That is it I'm afraid. The flash was unsuccessful. If you had an antivirus program loaded that will be why it failed. You can purchase pre loaded BIOS chipr on flea bay. All you need to do is find an engineer with SMD knowledge and replace it.
Oct 24, 2013 | HP Pavilion dv9310us Notebook
No backlight on hp pavilion dv8000 17" monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 10, 2012 | HP Pavilion Computers & Internet
Hi I have pavillion dv9310us notebook. From yesterday monitor display is not working. This was happened for a time and i could booted it again. But this time it is not.I can hear the fan is working. Please...
Hi Pradeep, I saw same problem with most of HP laptops (almost all series of dv-xxxx) this is the problem of nVidia graphics chipset, you have visit any service center to fix this problem, Thank you...
Do not buy or recommend HP dv series laptops with nVidia chipsets
please vote if found usefull
Aug 27, 2011 | HP Pavilion dv2610us Notebook
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Hi I have started my HP PAvilion dv9310us notebook all the keyboard lights are on but nothing is displayed on the screen it seems the notebook is turned off but it is on and running.
lights are on but nobody is home.
This is a problem seen in a couple of HP model lines (dv, and tx).
Short version...
Your motherboard is shot, I hope you are still under warranty as HP hasn't owned up to the design flaw that causes the problem enough to do a recall or offer replacement.
IF you have critical files that you need to get from the machine you may try the following, however this is not a long term solution...
1) turn pc on (lights are on fans are running, no hp spalsh screen, no nothing)
2) put pc in a bag (what ever you would carry your laptop around in should work, or wrap in a towel, the point is that it gets really hot)
3) wait 20-30 min.
4) turn pc completely off (hold power button for several sec or unplug and remove battery)
5) try rebooting (you may have to try a couple times, and I have a superstition that holding down F10 while powering on helps, once you see the HP splash you should be good to go)
6) Remember that HP makes devices with all kinds of cool features, but they almost always fail shortly after the end of thier warranty.
Nov 23, 2010 | HP Pavilion dv9310us Notebook
Both hinges of hp dv9000 broke now no displAY SEEN TOO
HP has a recall on the Pavillion lappys
if you call them and be persistent they will send you a box and all you have to do is send it in for a FREE FIX...
My DV9310us has been back to HP 5 times
Happy Fixing =)
Apr 06, 2009 | HP Computers & Internet
XP INSTALLATION
All you have to do is to access the BIOS then set the option of first boot device as CD then the second boot device as HDD or hard disk. When you turn on your HP you should see the option to go to the BIOS Setup sometimes its F2 or F12 or Del Depending on the type of motherboard you have on your laptop. Once you set it to boot from CD , when you startup your computer you should see press any key to boot from CD just press any key and it will boot. After the installation change back the first boot device.
If you have any other questions do message me back.
Nov 07, 2008 | Computers & Internet
N600C Bios Update
You can make a bootable cd of the flash image and update the bios that way.
Jan 20, 2008 | Compaq Evo N600c Notebook
HP Pavilion dv9310us Notebook Logo
518 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
