Question about Jenn-Air JJW8330D Electric Single Oven
Moffat oven i brought a moffat oven from wicks, unable to fit it to the electrical surply,due to no wiring, also no instructions
  • topseypol Feb 28, 2009
    We have purchased the above oven from wickes but there is no cable or wirng diagram supplied. Can anyone help?
    Polly
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
U need to open/unscrew back and look at bottom connections to the left ( looking from the back) Earth green and yellow- Blue is neutral and Brown is live you probably need electrical female spade connectors for your end of the 'hard' wire !!
Posted on Dec 21, 2008
Your going to have to find the electrical load requirements for your oven.
Then your going to have to run wires to your ellectrial panel box and install a properly sized circuit breaker.
Usally you are looking at 208 single phase wiring at 40 amps.
It's going to take sheilded wires plus open copper ground.
The colors of the wires usally are Red, Black, and white with a bare copper.
The white will go to common. the bare wire to ground at your panel box and the red and black will be connected at the rear of the oven on the terminals, the white white will also go to a terminal and the bare copper will be attached to a ground screw on the rear of the oven.
It would be best to use a metal sheilded wire for your supply wire, alot of people use ROMEX ( no metal sheild)
The best wire to use would be solid copper. You run your wires and connect the oven side first , also when wiring the circuit breaker it's best to wire it before you install the breaker into the panel box.
If you are not knowledgeable on the wiring and not familar with the panel box I would suggest you turn the main power off before opening or installing the circuit breaker.
Posted on Feb 01, 2009
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
Feb 05, 2015 | Moffat Ovens
Burnt wire at spade connector
If you are unable to catch the wire through the front of the oven where the terminals go through then you will have to pull the oven from the wall and remove the rear panel. Of course make sure the power is off before attempting the repair.
Nov 17, 2013 | Thermador SMW272 Electric Double Oven
I have Moffat E32ms 208V ,but my singal fase 240v. What I can do.
Those voltages are interchangable...you can hook it up with no problems...
heatman101
Aug 18, 2010 | Moffat E32 Full Size Electric Convection...
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Moffat 3000 oven
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Oct 06, 2008 | Ovens
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Jenn-Air JJW8330D Electric Single Oven Logo
299 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
