Question about LG LFC21760 Bottom Freezer French Door Refrigerator
My refrigerator shows an ice make but i can not find the connections to it
    New Friend:
  • 51 Answers
THE CONNECTIONS ARE BEHIND THE UNIT TURN IT AROUND AND YOU CAN SEE THE WATER HOSE CONNECTORS, YOU HAVE TO DO SOME WATER INSTALATION FROM AWATER SUPPLY THE MOST COMMON IS THE ONE BY THE KITCHEN/SINK. WHAT YOU NEED IS: A SET OF A COPER TUBE INCLUDE ONE SMALL REFRIDG WATER VALVE. MAKE SURE YOU LET ALL THE AIR OUT FROM THE WATER LINE BY KEEP THE WATER RUN THROUGH THE LINE FOR ABOUT 1 OR 2 MUNITS. AND PUTT EVERYTHING BACK TOGETHER
Posted on Oct 24, 2010
SOURCE:
My samsung refrigerator shows a icon that the ice maker is turned off. How do I turn the ice make on again
Press the ICE OFF button on the lower right side of the display. Push ON, Push OFF.
Jan 20, 2018 | Samsung Refrigerators
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
Ice maker, seems like the water fills the ice tray w/to much water, runs into the ice container and I have large clumps of frozen water in ice bin.
The water inlet valve is bad and needs to be replaced.
The valve is located in back of the refrigerator. You can follow the water line that connects to the refrigerator right to the water inlet valve to help you locate it.
Here is a video that shows you how to change a water inlet valve on a refrigerator. Though the video may not be specific to your model all refrigerators are similar.
I hope you found my post helpful.
Aug 07, 2011 | Refrigerators
Ice maker is on but not making ice
ur icemaker may have loose wire connections make all the connections fix or u may show to a nearest repair shop
Dec 27, 2010 | Sub-Zero 642
Evaperator icing up. timer r/r 3 weeks ago for same reason by a refer tech. started icing again yesterday.
Then there are other reasons for the icing. The defrost heater is defective, defrost thermostat, loose connections to defrost heater or low on freon. If you have a multimeter or ohm meter we can check the electrical. Lack of freon shows as a few rows are freezing on the evaporator and the other rows show only moisture. Let me know, Thanks, Sea Breeze
Jun 17, 2009 | Refrigerators
Connection to ice maker questions ?
supply water to inlet on valve. the solenoid valve meters the amount of water that goes into ice maker.
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
LG LFC21760 Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
