Question about Nerf Secret Strike As 1
I just bought an sspb(secret strike pocket blaster) and it has an air leak what can i do to get it to work properly?
3 Suggested Answers
SOURCE:
  • 1066 Answers
SOURCE: i bout a secret strike as1 nerf gun but it never work
easy...return it for one that works!
Posted on Mar 27, 2009
lordlangford
  • 11 Answers
The gun will work but don't be scared to pump it with a deal of force I found I had this issue also untill I fully pulled and plunged the plunger with a bit more vigor
Posted on Jun 16, 2011
I bought a Tommy 20 Air Blaster for my grandkids and after an hour of working with it, I still can't get it to shoot a dart. All it does is jam.
Fold back the blaster's Barrel, You should see a Orange square section with two copper metal pieces inserted in them on both the barrel and the cylinder housing those pieces connect are the both still intact? uf not You may have the same problem as I do.
Jun 26, 2011 | Buzz Bee Toys Air Blasters Motorized Disc...
New rotary nozzle will not work. will spin and then stop and repeats.
By rotary nozzle do you mean the dirt blaster? or a different accessory? if it is the dirt blaster it could be that there is air in the system. take the dirt blaster lance off, then pull the trigger with high pressure untill you get a complete flow of water. then put the dirt blaster onit should work.
Another thing that could have happened is if you have bought the wrong dirt blaster for your machine as there are different types for different models.
May 15, 2011 | Karcher Garden
What makes a car run hot and still have water?
The water may not be accurate. sometimes you can have air in your system and where you see coolant, is essentially a pocket of coolant.
Pressure test your system and look for leaks. Some vehicles have air bleeds that keep coolant from properly filling, and always have the heater on high during all coolant filling events or you can have large air pocket.
Nov 19, 2010 | YouTube Videos
I am having a terrible time sewing through several layers on trim on pockets that I attach to the front of tote bags. I sell these totes and need a polished, professional look. When I bought this...
try a
Jean-a-ma-jig or Hump-jumper
trying to sew over a bump of fabric, such as a thick jean hem, try using this tool
local fabric store should carry it
It keeps your pressure foot level as you sew over the
bump
you said your needle plate has many strike marks on it,,make sure you can't feel the strike marks so the fabric won't hang on them,,because marks on a needle plate can pulled the fabric
Sep 01, 2010 | Husqvarna Designer I
Need to find where to get info on how to sandblast
make sure first of all you have a big enough compresor to run ur sand blaster always put clean sand in it,try using a screen if u have to reuse sand if big enough chunks get in the sand it will clog up.hold away from object to be sanded about 3 inches away from area to be sanded.always keep blaster moving if u keep it in 1 spot to long u can warp the metal.other then that i dont know specifically what u need to know.
Dec 22, 2008 | Air Tools & Compressors
Only hot air blowing out of vents
i am a nissan master technition in Wichita Ks. we see this problem frequently. there is an air pocket in your heater core, due to low coolant level. for some resion or another your vehical is consuming coolant (usually head gkt leaking into cyl). and sence the heater core is higher than the radiator, the air pocket gets stuck in the heater core.
wait till the vehical is cooled off, remove radiator cap, install coolant funnel (avalible at any auto parts store). lift front of vehical off the ground (to get the radiator higher than the heater core), fill coolant funnel and start engine. allow vehical to reach opperating tempature and the air pocket will work its way loose. you may need to rev engine to change coolant flow rate in atempts to remove air pocket quicker.
sorry about the spelling
jon
Oct 09, 2008 | 2003 Nissan Altima
Nerf Secret Strike As 1 Logo
63 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
STEVE
FastHarley
FastHarley
Are you a Nerf Toy Expert? Answer questions, earn points and help others
