Why my laptop starts everytime in safe mode?I need to start normally
    Habit-Forming:
  • 144 Answers
Do you have a full windows CD - or a recovery CD ??
or what ??
you should be able to go into bios and change so that it boots from CD first
then you can format and install new operating system on that
BUT
make sure you know the hardware for you soundcard, video, and netwrok devices
it may be worth running if you can and save www.belarc.com
it may also be worth going onto the manufacuturers website and downloading all the drives for the PC before you wipe it __________________
Posted on Oct 24, 2010
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
SOURCE:
I updated my toshiba l300 pslgbe's bios from the 1.80 to the 2.2, now everytime i turn my laptop on, it shows a blue screen with an error. my laptop is now completely useless
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
May 18, 2011 | Toshiba Satellite Pro L300 Notebook
Hi everyone, I'm having the same problem too.. Everytime I start my laptop, It show these two option: Startup repair or Start Windows normally. I "Start Windows normally" and then it comes...
Hi.
It looks like your going to have to perform a full system recovery as you are not getting anywhere with start-up repair or safe mode.
For a full system restoration, press the F11 key during bootup and then select "Recover PC" from the menu.
Regards.
Jan 25, 2011 | HP Mini 1000 Netbook
When I start up my computer, i cant access anything on the screen. It just freezes and then I restart it and then it does it again. Help!
it is probably a program that starts up overloads the system resources, so everytime it starts it freezes. what you can do is go into safe mode (go into safe mode by hitting f8 right before windows logo comes up when you start your computer, or right after dell logo. either that, or if you restart it wrong, it should give you the option of going into safe mode) then when you log onto your account, a window will pop out, just click yes. then either go to start menu on run(if you have windows xp) and type msconfig. then a window will pop out, when it does, go to the startup tab, and uncheck all of the boxes. click ok, and click restart, (for windows 7 its the same thing but instead of using run, just type it in the search bar on the start menu). go to start windows normally, if it still doesnt work, when you restart it, go to last known configuration. Hope this helps. If you need any clarification, just let me know, ill check in. Goodluck
Jan 18, 2011 | Dell Latitude E5500 Laptop
When I boot up my laptop, it asks me 4 options. Start windows normally, safe mode, safe mode with command prompt, and safe mode with network support. It doesn't matter which one I pick, but when the laptop...
To start your computer normally you must choose either of that options but the only thing you must choose is the start windows normally so that all the settings from the previous working settings will be applied in your windows start up.
Dec 25, 2010 | Toshiba Satellite L45-S7423 Notebook
My presario m2000 will turn on but comes up with a screen
This is happening because you're not turning the computer off properly, make sure everytime you turn your computer off you go to
Start menu
Shut down.
You need to select start windows normally.
Safe mode will help you with some otherthings
just make sure of turning the pc off properly ;)
Apr 27, 2010 | Compaq Presario M2000 Notebook
I had my laptop fixed 6 months ago and i was told i no longer have safe mode. I recently made a mistake and set my computer to start in safe mode. Now i can't get it back to normal mode. The screen says...
who ever fixed your laptop must has done some thing that has led you to this issue....it's just not possible that you wont have Safe Mode, it's one of the inbuilt safety system of Windows OS....press F8 to get into the option to go to Safe Mode or.....Normal mode of operation.....
You need to press F8 before the Windows screen appears...after you switch ON your laptop.
Dec 10, 2009 | Microsoft Windows Vista Home Premium...
Everytime I boot up I am in safe mode. how do I get out of safe mode This is for a Toshiba Satellite: A 105-S1013
When the system boots up, click on the start button, then click on run and type msconfig and hit enter. Go to the Boot tab, look at the lower box and uncheck "safe boot" if it is checked.
Dec 06, 2009 | Toshiba Satellite A105-S1013 Notebook
My laptop cant use in noraml mode and it turns to white
resetart the laptop and choose "Debugging mode". This will show the list of files that loads during the initial boot up and OS starting. Reply with the last file listed before the BSOD.
If the BSOD occurs after the logging, list where it occurs (during the "Starting Windows XP window" or "after the desktop appears but no desktop icons".
Also, provide what OS is on the laptop.
Nov 18, 2009 | Sony Computers & Internet
Start up problem
try to disable start up items that are not required...for that u have to boot in safe mode and type msconfig in Run
Dec 10, 2008 | Compaq Presario Notebook
Open Questions:
WISCONSIN 1=855=536=5666*$+ Crypto support number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 21, 2019 | Epson Computers & Internet
Computers & Internet Logo
21 people viewed this question
Ekse
Marvin
Marvin
