Question about Garmin GPS 12 GPS Receiver
Garnin 12: Half the function keys no working.
Power, quit keys working, page, Mark, enter and go to keys are not working. Receives satellites.
    Problem Solver:
  • 4 Answers
It could be that the contact on the board under the keypad are dirty. I have that problem many remote control units, I use a pencil eraser to clean the board.
Hope this helps.
Mike
Posted on Aug 26, 2008
Toshiba Satellite not Booting (No post Screen)
you can't boot on safe mode under F8 function key?
Mar 30, 2014 | Computers & Internet
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
Toshiba Satellite Tablet R15-S829 Function Keys not working
Check keyboards tab in device manager: control panel>hardware and sound>device manager; and check the driver is installed correctly. i.e. has no red or yellow icons showing. Right click and choose update driver.
Mar 13, 2012 | Toshiba Computers & Internet
My Garnin 660 can't receive any satellites with its own antenna, even if I am out in an open area As soon as connect Garmins (GA25) extra antenna it works fine. Can anythig be done?
Hi
it could be the internal antenna is broken.
Have you tried installing all the firmware updates on the device from the gamin website.
They have done quite a few and it is possible one could improve sensitivity.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Garmin Nuvi 660 GPS Receiver
What are the parts of casio calculator
LBrown18062@hotmail.com My manual is 75 pages. I can email it to you. Please put Casio FX-115ES as the subject. Awaiting your response.
fx-115ES User's Guide
About this Manual
• The MATH mark indicates an example that uses Math format,
while the LINE mark indicates Linear format. For details about
input/output formats, see "Specifying the Input/Output Format".
• Keycap markings indicate what a key inputs or what function it
performs.
Example: 1, 2, +, -, !, A, etc.
• Pressing the 1 or S key followed by a second key performs
the alternate function of the second key. The alternate function is
indicated by the text printed above the key.
• The following shows what the different colors of the alternate
function key text mean.
If key marking
text is this color: It means this:
Yellow
Press 1 and then the key to access
the applicable function.
Red
Press S and then the key to input the
applicable variable, constant, or symbol.
Purple (or enclosed Enter the CMPLX Mode to access the
in purple brackets) function.
Green (or enclosed Enter the BASE-N Mode to access the
in green brackets) function.
• The following shows an example of how an alternate function
operation is represented in this User's Guide.
Example:1s(sin-1)1=
Indicates the function that is accessed by the key
operation (1s) before it. Note that this is not part
of the actual key operation you perform.
sin-1{D}
Keycap function s
Alternate function
Jan 19, 2011 | Casio FX-115ES Scientific Calculator
Where is factorial button on ti-83 plus
Not every function on the TI83Plus calculator has a dedicated key, or is accessible through a key sequence. Among the keyless function is the factorial function.
To access the factorial function
  1. Through the catalog of commands: press [2nd][0] (CATALOG) and scroll Up till you reach the exclamation mark !
  2. Press [MATH]. Use right arrow to highlight PRB menu. The factorial function is the 4th in the list.
Syntax
Type the number and use one of the foregoing access methods to echo the exclamation mark on the home screen and press ENTER.
Ex: 12! =479001600
The largest number that you can use with the factorial is 69.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-83 Plus Calculator
Standard Horizon CP-150 won't find satellites
Robert
It could be the RAM inside the plotter needs to be reset, Try the following procedure:
RAM Clear
Please note this procedure will erase any saved user points such as marks and routes and will put all of the internal settings back to factory default. In addition the unit will have to reacquire satellite signals, which may take a minute or two. If you have a large number of routes and/or marks you may wish to save them to a User C-Card prior to performing the RAM clear. The User C-Card is a blank memory card that is available through your local dealer or can be purchased from C-Map directly by contacting them at (800) 424-2627.
1) With power to the GPS turned off press and
hold the ENTER key.
2) Now press and hold the PWR key.
3) Keep both keys pressed until the GPS screen lights up and you see the SYSTEM TEST page displayed, then you can release both keys.
Note: If the GPS is not able to be turned off using the PWR key you can turn power off at the breaker or disconnect the power cable, press and hold the ENTER key then turn the breaker on or plug the power cable back in.
4) Make sure that the RAM menu function is selected, then press the ENTER key.
5) A sub-menu will appear that has two selections; RAM test and RAM clear, move the shuttle point knob down to select RAM clear.
6) Press the ENTER key, a prompt will appear asking if you are sure that you want to clear the RAM. Press the ENTER key to confirm and a prompt will now appear that informs you that the RAM has been cleared.
7) Press the CLEAR key and you will be back on
the SYSTEM TEST page.
8) Press and hold the PWR key until the unit turns off, then press and hold the PWR key until the unit turns back on again.
Sep 06, 2009 | Standard Horizon GPS
Function keys dont work
Go BIOS and check if the FN key be disabled.
Nov 11, 2008 | Toshiba Satellite 5005-S504 Notebook
Garmin GPS 12 GPS Receiver Logo
67 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
